Stop me and my drill! Pivot question...
I have an overwhelming urge to drill out the pinned pivot on one or more of my Spydies in order to put in a tension-adjustable screw - how bad of an idea is this? I assume I can find suitable screws for the replacements somewhere, excepting the Salt series (H-1 or titanium)? Also, I've heard that if one is handy with a hammer and solid metal rod, it is possible to increase the tension of a pinned pivot - if so, instructions would be greatly appreciated, and may prevent me from taking the drill out of the closet...thanks in advance.
STR's Blog
STR's Blog
- sharpguitarist
i found an old, used, sprint run, grey frn ce ladybug at the flea market, and it had some bladeplay.
what i did was put the pivot pin in the jaws of a small vice.
i gradually increased the tension on the vice. checking the knife between tries, until there was no play.
seemed like i had more control with this method than beating on it with a hammer. :eek:
just beware, if you go to far, your knife will become very difficult to open.
hope this helps!
later,
don
hope this helps!
later,
don
