How does G10 stand up to misuse?
One of the things I love about my SS Delica is that the handle is a great prybar and impact tool. Yesterday, a drawer in a metal storage locker jammed, and I was able to easily pry it open with the closed Delica. When the clip on my dog's chain freezes in winter, I pound on it with the knife handle to get it moving again. Can I do these things with my Caly3 and Para? The Caly has full liners, so it should be rigid enough, but will the G10 crack? I'd prefer not to baby my pricy knives, but I don't want to break them either.
I titled this thread "misuse", but actually I think a useful handle adds value to a knife. Makes it a more well-rounded tool.
No man can ask for greater gifts than wisdom and patience.
For your application, I would say stay with SS handle. Anything other than your specialty usage, G10 is a much better handle material in every attribute
LBK3S|C52BK|C106PYL|745|943|C08CFS|C52m|C36GPBK|C10GPFG|1003UBK2|14210|C123CFP|C81FG
C28WH|1600DAM|C105|RC4S|C51GPFG|1735OR|830675|C90CF|C123TIP|CS97KMS|BRKT-CS|BRKT-MC
BRKT-LC3V|C101XHP
BRKT-LC3V|C101XHP
- The Deacon
G-10 is pretty tough stuff but, as has been noted, it definitely won't take the level of abuse/misuse that steel will.
Lined G10 is still pretty tough. Using the handle as a "hammer" you would be impacting the steel liners and G10 simultaneously making for a pretty sturdy surface. As it would absorb less than FRN I would think it would be more effective.
You could also get a mini-pry bar from CountyComm or a custom maker like STR.
Now that you mention it, I just thought of my dream tactical SD folder: Military with g10, comp lock, full-length skeletonized steel/titanium liners.Blerv wrote:Lined G10 is still pretty tough. Using the handle as a "hammer" you would be impacting the steel liners and G10 simultaneously making for a pretty sturdy surface. As it would absorb less than FRN I would think it would be more effective.
:spyder: Keep you blades sharp and your wits sharper :spyder:
- monsterdog
I find SS a bit too heavy & slippery and I prefer the light, grippy feel of G10 or other scale materials. To be honest I winced a bit when I heard of a Delica being used as a hammer and pry-bar and I'd say it's a fair thing to do if you are in a survival situation but if you can carry a separate pry-bar then it would be a much better tool
My spydies: Squeak, Tenacious, Terzuola, D'Allara, UKPK CF peel-ply pre-production, UKPK CF smooth pre-production, UKPK G10 orange leaf-blade, UKPK FRN grey drop-point, UKPK FRN maroon leaf-blade, Bug ... all PE blades :)
To be fair, I'm not prying or hammering with the blade. That would make me wince too. However, I do like to minimize the number of things in my pockets, which is why I prefer tools that can fill multiple roles rather than one tool for each possible job I might encounter. I own several LeathermenChrisR wrote:I find SS a bit too heavy & slippery and I prefer the light, grippy feel of G10 or other scale materials. To be honest I winced a bit when I heard of a Delica being used as a hammer and pry-bar and I'd say it's a fair thing to do if you are in a survival situation but if you can carry a separate pry-bar then it would be a much better tool![]()
Thanks for the comments on the strength of G10. Some things are better not to find out the hard way. :D
