Nylon bushings
Iole
Nylon bushings
Post by Iole »
How well will nylon bushings hold up compared to metal? Does "plastic" fall apart over time?
JNewell
Post by JNewell »
Do you mean true nylon (usually white) or "nylatron" (usually gray)? They are close to being at opposite ends of the performance specturm.
Iole
Post by Iole »
JNewell wrote:Do you mean true nylon (usually white) or "nylatron" (usually gray)? They are close to being at opposite ends of the performance specturm.
The white colored ones.
Slick
Post by Slick »
Iole wrote:The white colored ones.
Solid nylon is amazingly tough stuff and very slippery. The very solid hard white stuff.
Not really all that slick ;)
Iole
Post by Iole »
Is it then a long wearing material for folders? Almost as good as an metal bushing?
JNewell
Post by JNewell »
Iole wrote:Is it then a long wearing material for folders? Almost as good as an metal bushing?
No. Nylon and teflon bushings will wear much faster. The gray/black nylatron washers are considered by many people, including some knifemakers who know what they're talking about, to last as long as PB. I've never seen a comparative test.
Jimd
Post by Jimd »
The gray ones that Emerson uses last a very long time.
Referee in the Bowels of ****
Email: ST8PEN01@aol.com
Artwork For Sale
"...We few, we happy few...we band of brothers...For whoever sheds his blood with me today shall be my brother." - William Shakespeare
If you are not willing to stand behind our troops, by all means, please stand in front of them!
JNewell
Post by JNewell »
Jimd wrote:The gray ones that Emerson uses last a very long time.
Correct - those are nylatron, not white nylon, though.
Jimd
Post by Jimd »
JNewell wrote:Correct - those are nylatron, not white nylon, though.
I believe you're correct. They last for years and years.
Artwork For Sale
bdbender
Post by bdbender »
Howdy -
As I posted over in the Walker CF thread, I am curious about what the bushings in that knife are. They are slightly off-white, and I have seen both nylon and teflon of that color, but I don't want to guess or speculate. Does anybody actually know? Thanks.
spoonrobot
Post by spoonrobot »
The terms bushing and washer aren't interchangeable. This thread appears to be about washers, not bushings.
This is a bushing:
http://i291.photobucket.com/albums/ll30 ... MG1569.jpg
These are washers:
http://i291.photobucket.com/albums/ll30 ... MG1572.jpg
From this thread (which has the washers mislabeled as well):
http://spyderco.com/forums/showthread.php?t=42441
nathan310
Post by nathan310 »
I was thinking the same thing.
Never mistake kindness for weakness.
gull wing
Post by gull wing »
Glad you straightened the Bushing/Washer thing out.
SCARAMOUCHE! :bug-red-white
Post by The Deacon »
Even the Manix 2 type pivot is not a bushing in the strict sense of the term. A bushing is a bearing, it is not a shaft, it surrounds a shaft or, to look at it another way, lines a hole in an object that a shaft then passes through. A 1911 has a bushing around the barrel. Crankshaft bearings on most automobile engines are two piece bushings, or at least were back in the days when I worked on engines.
