Can you easily one hand a Dragonfly?
When I got a Ladybug 3 one hand operation was awkward (I'm a Native guy) but after opening and closing it a couple thousand times I can one hand it just fine.
The Dragonfly resists my thumb opening advances, that built in pocket clip causes it to roll in my fingers when I try to thumb the Spyderhole. Using thumb nail or thumb pad makes little difference, the Dragonfly just doesn't cooperate.
Getting a Dragonfly by the hole and swinging the handle down with finger tips works as would a Spyder Drop or Spyder Wave after the knife loosens/smooths up but thumbing it open just doesn't.
Anybody else have the same problem? Any advice?
Thanks
Thanks
- Bluntrauma
I EDC a SS Dragonfly and I find I have no problems with it. It's a great little knife. I use it for all kinds of stuff, I was even able to use it in a closeed position to open up a bottle that didn't have a screw off cap the other day. I find new uses for it all the time. It's kind of my beater knife, but I still love it.
				yablanowitz
- vampyrewolf
the ss 'fly does loosen up nicely after opening a few hundred times (which in reality is a bored weekend on the couch).
My glasshart engraved is still nice and tight, but my edc ss is nice and loose after 7 years of heavy use (quite often bordering on abuse). Have to get around to grabbing an engraved one while my local still has stock.
Coffee before Conciousness
- Lord vader
I took me a while to quit laughing to be able to type this,Anyway i have done that too.A knife would never get broke in if a person only opened there knife when they really needed to.The good way to accomplish proper break in is just as you mentioned. :)vampyrewolf wrote:the ss 'fly does loosen up nicely after opening a few hundred times (which in reality is a bored weekend on the couch).
If you want a super smooth knife run your bathtub half full of warm water hold the knife under and move it in a choping motion rapidly a few times take it out and soak it down with oil let it set all night then rub with a rag inside out openingg and closing several times and wiping the oil as you go
						- phillipsted
