The Probe, questions
dete
Post by dete »
The Probe or the mini,
I'm wondering what is the purpose of the extra holes on the blade
they definitely do not look like they are their just for looks...
thanks in advance for any info!
Post by The Deacon »
You mean the hole in the spine with a slit leading into it? That's a wire cutter. If you mean the small projection on the handle that extends forward above the thumb ramp on the right, that's for hooking to a surgical tubing sling/lanyard.
dete
Post by dete »
The Deacon wrote:You mean the hole in the spine with a slit leading into it? That's a wire cutter. If you mean the small projection on the handle that extends forward above the thumb ramp on the right, that's for hooking to a surgical tubing sling/lanyard.
you nailed both exactly! thank you.
very interesting knife I might add.
:cool:
shabbasuraj
Post by shabbasuraj »
dete wrote:The Probe or the mini,
huh?..........
tomahawk23
Post by tomahawk23 »
It a probe. It Probes things.
A Man Without his Knife is like a Bear Without its Claws.
Peter1960
Post by Peter1960 »
tomahawk23 wrote:It a probe. It Probes things.
Are you serious? ... A shut mouth catches no flies :rolleyes:
Spyderco's company motto
