Posting Problem
Clay Kesting
Posting Problem
Postby Clay Kesting » Fri May 11, 2001 12:00 am
Whenever I post a reply I get this message:
"There was an error = [Microsoft][ODBC SQL Server Driver][SQL Server]Line 1: Incorrect
syntax near '='. Use you back button to correct the problem."
If I ignore it, as I always do, I find that my message has gone through anyway. I guess if I used my back button as directed, I'd get a multiple post. It's been happening for some time and I haven't worried about it too much except that it's affecting my post count <img src="sad.gif" width=15 height=15 align=middle>. It hasn't gone up since the problem started and I reckon I should be up to about 290 by now <img src="smile.gif" width=15 height=15 align=middle>. Is it something I'm doing wrong or a software problem?
Clay
Mancer
Postby Mancer » Fri May 11, 2001 6:04 am
Hmmm strange, I havent been getting anything of the sort, mabey its just due to network congestion or something of the sort, hope it clears up 4 u soon.
Seeya
MaNcEr
It's Time To Kick @$$ 'N Chew Bubble Gum
knifenerd
Postby knifenerd » Fri May 11, 2001 8:40 am
Clay, I have had the same problem. At least once, it resulted in a double post. I think it's better to ignore the error message.
Dick
knifenerd
Postby knifenerd » Fri May 11, 2001 8:49 am
Just had the problem again. This is some kind of software problem. I ignored the error and the post went through.
Dick
The Stare
Postby The Stare » Sat May 12, 2001 12:24 am
Maybe that explains the possible "record" 15 taps seen in a thread recently. Somebody as stubborn than the software kept trying??
While we're at the software subject -- a very smooooth segue, IMHO -- what is with the "Check here Remember Details" option box below the signature option box?
Stare
knifenerd
Postby knifenerd » Sat May 12, 2001 7:21 am
Stare - - I think it means that it remembers your "cookies" so you don't have to log in each time you visit.
Hopefully, the software prob. will be worked out before the server starts to load up with people making multiple posts.
Dick
Clay Kesting
Postby Clay Kesting » Fri Jun 01, 2001 3:36 pm
I'm still having the same problem. Is it just me or are others still getting the same message?
Clay
Clay Kesting
Postby Clay Kesting » Fri Jun 01, 2001 3:39 pm
How very strange. It didn't happen when I posted that last message, but did when I posted a reply to the "Ladybug" thread a minute or so before. I wonder if it's a "cookie" problem. Let's see what happens when I post this.
Clay
vampyrewolf
Postby vampyrewolf » Fri Jun 01, 2001 4:28 pm
I used to get the problem, just not clicking on "remember signature" seems to help.
Then again, I just posted, used sig(this is an edit), and it worked. Odd...
Edited by - VampyreWolf on 6/1/2001 4:29:03 PM
chinook
Postby chinook » Fri Jun 01, 2001 5:42 pm
I am starting to get a feeling of inadequacy. The same error mssg no matter what I do.
Oh well, It's not the only one telling me I screwed up. <img src="smile.gif" width=15 height=15 align=middle>
SharpeML
Postby SharpeML » Fri Jun 01, 2001 10:35 pm
I'm having the same problem. My number of posts is also not incrementing. I just ignore it like Clay and post seems to work anyway.
The Stare
Postby The Stare » Fri Jun 01, 2001 11:48 pm
Posting only to check the details box in hopes of obtaining cookie so don't have to log on for each post.
Stare
sam the man..
Postby sam the man.. » Sat Jun 02, 2001 1:41 am
G'Day Clay!
Think the post-counter had gone coo-koo on you mate.. <img src="sad.gif" width=15 height=15 align=middle> Hope someone could provide an explanation in this phenomenon...
Sam
have spydies will travel
Mark
Postby Mark » Sun Jun 03, 2001 2:25 pm
just got same message and ended up triple posting
seth
Postby seth » Sun Jun 03, 2001 2:47 pm
Ok, I'm going to take a stab. The Object database connector (ODBC) SQL Server Driver is a software driver than translates data between two unique Stuctured Query langauge (SQL) databases. These little codecs reside on the client side PC. They gernrally are customized to translate between two specific databases. This allows for proper syntax matching.
It is possible that the folks with this error message have a ODBC driver(s)loaded on their PC, that gripes with uploading to the Forum SQL server, due to a header configuration conflict. The posts are OK, but the client PC gripes anyway.
I hit this server from about five different boxes, but I know each box's configuration and square up the ODBC in the control panels.
In short, It may be client-side rather than server side.
Hope this helps, I tried to keep the techie talk to a minumum.
Then again, it could be due to solar flares.
chinook
Postby chinook » Sun Jun 03, 2001 4:49 pm
butt it was nighttime........><g>
Clay Kesting
Postby Clay Kesting » Mon Jun 04, 2001 1:00 am
Seth,
I wondered if it might be a problem with my computer. However the funny thing is, I don't get the message posting to this thread or starting a new one but I do get it everywhere else.
Clay
Clay Kesting
Postby Clay Kesting » Mon Jun 04, 2001 1:02 am
****, now I'm getting it here too and I didn't 3 days ago.
Clay Kesting
Postby Clay Kesting » Sat Jun 30, 2001 12:55 am
Mmmmmmm...I think I might have the answer. I'm in the habit of going to "Show topics for the last day" and clicking on "Go". When I do that I always get the error message. However, today I opened up the forums individually and there was no error message when I posted. You beauty, now my post count will start ticking over again, look out Samo and Carlos <img src="smile.gif" width=15 height=15 align=middle>
Clay
knifenerd
Postby knifenerd » Sat Jun 30, 2001 12:05 pm
These problems have been around for quite a while. As far as I know, forum administrators are aware of it. Maybe it's an inherent prob with the software.
Dick AKTI #A001365
Users browsing this forum: -swk-, 5-by-5, benben, Bing [Bot], dan31, Fireman, FullFlatMind, GoBlue93, Google [Bot], I_like_knives, JD Spydo, rcwill98, remnar, SpyderGrill, termite, tomcatt1 and 37 guests
