WHY WON'T ANYONE ANSWER ME????
theginsu
Post by theginsu »
I NEED HELP ON POCKET CLIPS (SEE OCT.10 POSTING)I want to cut down the the pocket clips and bend the ends in(curved in under-neath), so that they don't show as much when in the pocket or waist band. Will the clip snap if I try to bend it, after cutting some of it off? I want them to look like a pen pocket clip, with the end curved in and under, instead of curved up, as they are now.
Blades
Post by Blades »
Welcome to the forums!! I like your idea. I don't know how well it would work, but it is worth a shot.
I would try bending it in first before cutting. You might need to heat it to bend it without breaking. Its hard to say. You might have better luck with a titanium pocket clip. Good luck.
Blades
ftkinney
Post by ftkinney »
someone asked that a long time ago and i believe the ansewr from some of the more knowegeble forumites stated that the steel in the clip is very hard like spring steel and would snap if you go to the teckno jukie's forum they could tell you were to go to buy the matterials to make your own "deep carry" i think if you search the forum with this you migh get the old thread i'm talking about, good luck.
FTK
theginsu
Post by theginsu »
thanks. i'll try it.
