reverse S: cricket or meerkat?
DamnYank!
Post by DamnYank! »
looking at picking up a reverse S office carry pocket knife. Leaning towards serrated...
not sure to look towards the cricket or the meerkat.
recommendations and experiences welcome as well as where to find these...
Thanks!
zenheretic
Post by zenheretic »
Cricket is much thinner and easy to carry in slacks/fits in a watch pocket perfectly.
Meerkat is just a cool little knife, with better ergos.
If you do a lot of cutting the ergos weigh in, otherwise I'd go with the Cricket.
Follow the mushin, but pay it no heed.
Mr Blonde
Post by Mr Blonde »
For pocket carry, the Cricket is best. It was designed to carry as comfortable in your pocket as a riverside pebble, according to the Spyderco Story. I took the clip off of mine, added a lanyard and dropped it in my pocket. It worked great, though I replaced it with a Navigator II with the same modifications. I prefer the more conventional blade shape of the Navigator and the more solid feeling construction.
Wouter
Last website update: 07-31-2025 Instagram
greencobra
Post by greencobra »
The Meerkat is one hot, overlooked knife. Even better with reverse S blade. Fits my big meaty hands pretty good so I have some decent control when cutting something. It's too bad it couldn't be redesigned with the top lock system so it could have another go with the buying public.
Avatar by Dialex
steeldust
Post by steeldust »
Listen to Zenheretic! The way it fits ones hand is toooo good to be true! :p For the way it's built I think it's quite a bargain. Of course, the only way to be sure is to get Both! :D
jaislandboy
Post by jaislandboy »
I agree with zen and steeldust about the Meerkat....great ergos that will feel more comfortable in the hand if you will be doing lots of cutting...versus the SS cricket....but then you factor in the Aus6 vs. VG10 steel as well as the thinner more discreet SS Cricket that fits neatly in your "change" pocket and you'll probably wind up getting both! :eek: :D
brian
dialex
Post by dialex »
Just as my forespeakers already said, both are great knives and no matter which one you'll pick, it will serve you well.
The Meerkat is more bulky and the Phantom lock™ is a really cool feature and quite a conversation piece, but the Cricket is quite a looker itself too. Not to mention it is very slim and it doubles as money clip. I'd lean towards the Cricket myself - shiny slim knives are my favorites ;)
deeker
Post by deeker »
The Meerkat is set up with a deep pocket carry clip, as well. It hides nicely when clipped.
psimonl
Post by psimonl »
Those are two different things. Aus-6 vs VG-10? there is no comparisions.
Yes, if you cut a lot, the Meerkat has better egros, but you will have to sharpen it more often. And it is now out of stock, but quite easy to get... And quite heavy for its size. But what a fun little animal....
With all the love I have for the little Meerkat, I would suggest you go with the SS Cricket for office use...
Simon
"Everyday above the ground and vertical is a good day".
-Sir A. Hopkins in "The world's Fastest Indian"
"If it hurts, it means you're not dead..."
-Kayakist Marie-Pier Cote
The Spyderco Cookbook
spd9075
Post by spd9075 »
I really love my Cricket....I just drop it in my pocket and go. Very sheeple freindly, too. I usually get..."aww that's cute" which turns into a "Man, that's cool!" when they witness the carnage and aftermath! It really is a great cutter. I cannot compare it to the Meerkat, since I've never used one.
:spyder: God Bless :spyder:
yablanowitz
Post by yablanowitz »
Whatever you do, don't buy a reverse S Meerkat (until I get mine, that is!). I didn't really like the look of the Reverse S blade until I bought a Cricket and tried it. WOW! I love my Meerkat, and that reverse S blade can only make it better. I really think the Meerkat is the most underrated knife Spyderco has made.
Rainy County
Post by Rainy County »
They are both great knives(of course :rolleyes: )but the main diference is that the Meerkat has alot thicker handles and is a bit longer too but the blades are almost the same. The diference with the blades is that the curves on the Cricket's blade is a little more pronounced then the Meerkat.
"Believe in the Lord Jesus, and you will be saved-you and your household." Acts 16:31
DamnYank!
Post by DamnYank! »
thanks for all the feedback guys!
i've held a meerkat before, but never a cricket... any in hand cricket pics?
spydutch
Post by spydutch »
DamnYank! wrote:thanks for all the feedback guys!
Here you go ]VERY[/B] effective) knife :D
(Yes I know I smoke a little too much :o )
DamnYank!
Post by DamnYank! »
thanks Dutch!
razamataz
Post by razamataz »
If you can find one get yourself a golden meekkat, they are a much better steel and is built like a tank. I cant help but side with the majority when they say the meerkat is the most underated knife spyderco makes. it will be the next dodo soon enough.
