SM 100 Nitinol for Spyderco
- SpyderEdgeForever
Sal and all check this out:
https://eknives.com/blog/why-sm-100-bla ... nifemakers
It is a Nitinol Nickel Titanium alloy that can reach 61 to 67 RC Hardness.
Re: SM 100 Nitinol for Spyderco
Old news and there are good reasons knifemakers aren't commonly using it. Starting with price: $150 for a 6" long, 3mm thick, blade blank.
- SpyderEdgeForever
Expensive.
That reminds me of a nanotech engineer who told me in a discussion I had about wanting Spyderco to produce Diamondoid steel blades. He said he has made, in a real lab, a fullerene based steel in which the iron atoms are bonded with and encapsulated by Carbon 60 covalent molecules that would be both tough and elastic and rust resistant, and be hardened to the RC 70 to 75 level.
I told him that is so cool and he said if sal and Spyderco wanted to contract with him to use it, it could be done.
I asked him "What is the downside to this?"
Ready?
He said unless a way was found to bring the cost down, each knife would have a retail cost of 1000 to 2000 US Dollars per inch of the material.
So Spyderco would have to charge you and me say 4000 to 8000 dollars for a 4 inch long blade.
Want a Mule of that? :)
Materials science. What a fascinating job to have. We will no doubt have new and interesting materials to play with coming down the pipeline on a regular basis over the coming years. I was told of a 1/8 inch rod of ? material that was used as a one inch part of a drive line on a big rig and they were unable to break it, even hauling a full load! I have been blessed with long time friends that worked for Lockheed Martin, and even though they won't talk about their work, (and never will), little tidbits pop out over the campfire B.S. sessions.
- 8th_Note
EKnives is local to me. I went to their brick and mortar shop for the first time the other day. I was impressed. They have an amazing inventory on hand.SpyderEdgeForever wrote: ↑Mon Feb 16, 2026 3:40 amSal and all check this out:
I bought 2 Spydercos while I was there too
- SpyderEdgeForever
Very cool. What was that like? Did they have Spyderco?8th_Note wrote: ↑Thu Feb 19, 2026 2:33 pmEKnives is local to me. I went to their brick and mortar shop for the first time the other day. I was impressed. They have an amazing inventory on hand.SpyderEdgeForever wrote: ↑Mon Feb 16, 2026 3:40 amSal and all check this out:
- 8th_Note
Yes, they have a showroom with many many high end brands that you can try out. Spyderco, BM, Hinderer, Spartan, Microtech, Bastinelli, Heretic. It's quite impressiveSpyderEdgeForever wrote: ↑Thu Feb 19, 2026 2:34 pmVery cool. What was that like? Did they have Spyderco?8th_Note wrote: ↑Thu Feb 19, 2026 2:33 pmEKnives is local to me. I went to their brick and mortar shop for the first time the other day. I was impressed. They have an amazing inventory on hand.SpyderEdgeForever wrote: ↑Mon Feb 16, 2026 3:40 amSal and all check this out:
electro-static
Fine edge holding similar to elmax, other than weight (and corrosion resistance) can’t see much of an advantage over current PM blade steel grades.
ImaCutSumSchitt84
The Ferrum Forge guys have multiple videos from back during the SM100 Stinger run. I can't remember if they showed it performing, but Elliot did nerd out on it at length if you're curious for more first hand info on the material. The article being a decade old I wonder about it's current price, if dropped considerably then Spyderco would definitely be the production knife company who could make it happen. A run of Mules would be awesome, I mean they did ceramic blade so why not give this a shot.
PM2 15v, PM2 BB K390, Sage 5 LW Rex121, Shaman 15v, Shaman BHQ DLC M4, Shaman Cru-Carta, Para 3 DLT DLC Cru-Wear, Para 3 BB K390, Para 3 FL Elmax, GB Folder 2 M4, Slysz Bowie M390, SpydieChef LC200N, Native Salt LC200N, Domino BB CTS-204p, Delica 4 K390, Dragonfly S30V, Manix 2 s110v, Manix 2 LW, Manix 2 Maxamet, MT27 PD#1 Amboyna burl, MT39 CPM15V G10, MT46 Magnamax G-carta
Wishlist: Domino 2 compression lock Magnacut, Chaparral Rex121, Bodacious 15v sprint, Rereleased Slysz Bowie Magnacut
A ten year old super steel? I'm at the front of the line!
Not a steel since it is a nickel-titanium alloy. I would take the Elmax edge retention claim with a grain of salt. It is free of carbides so only the hardness provides wear resistance. So it would be similar to a low alloy simple steel with low wear resistance. The few knifemakers that use it sometimes will say that it grinds terribly so they claim that means high wear resistance. They don’t know that the poor grinding is due to low thermal conductivity similar to straight titanium.
