What is your favorite high Carbon non stainless steel?
Red Leader
Re: What is your favorite high Carbon non stainless steel?
#41
Post by Red Leader »
Evil D wrote:
Thu Nov 27, 2025 6:38 am
Synov wrote:
Thu Nov 27, 2025 5:06 am
3V can do anything.
If Spyderco ever make something else in it I'd be happy to try it out but it's slim pickings unless you go outside of the brand.
I sort of wonder if 3V gets passed over a lot because 1) It is primarily used in fixed blades and 2) the only folders really using it probably don't have a great heat treat and are silly thick.
I think most of the potential of 3V, or even 3V Mod, is untapped. I'd be really curious what happens to it, and to it's edge, when pushed to the very end of the performance envelope - thin geometry, higher hardness, optimized heat treat recipe...it could do some wonderful things.
Right now it is being judged for primarily what it can do in less-than-ideal applications. Imagine what it could do if someone really took the same time with it that was done with 15V.
BeggarSo
#42
Post by BeggarSo »
I admit I dont know much about 3V other than stuff I read here years ago there was a guy here who used a kangaroo as his picture who had a Spyderco knife and he chipped it on some bone doing some tests. I am pretty sure it was 3V I know it was a fixed blade Spyderco.
I remember thinking well so much for 3V.
Danke
#43
Post by Danke »
I think the Tuff was the only 3V but if I'm wrong someone will be here quick to correct me.
Synov
#44
Post by Synov »
Danke wrote:
Fri Nov 28, 2025 9:29 am
Correct, that's the only one. There is no Spyderco fixed blade made of 3V. And I highly doubt the Tuff would chip on bone.
S90V: Nirvana Military 2 CF Native 5 Fluted CF Manix XL CF Yojumbo CF Shaman CF Sage 6 CF Native Chief CF MagnaCut: Native 5 Fluted Ti PM2 Crucible CPM-154/S90V: Manix 2 CF 15V: PM2 Marble CF 4V: Manix 2 Marble CF 3V: Tuff REX 121: Sage 5 CF 20CV: Subvert CF ZDP-189: Dragonfly 2 Nishijin S30V: Sage 4 Damasteel: Native 5 40th Anniversary VG-10: Delica 25th Anniversary N690Co: PITS XHP: Chaparral Birdseye Maple
Danke
#45
Post by Danke »
Maybe Wolverine's Adamantium skeleton would give it pause.
#46
BeggarSo wrote:
Thu Nov 27, 2025 4:29 pm
Aren't HAP40 and REX45 pretty much the same thing?
Just from what I read (I am no expert myself by any means) they are indeed.. except that some say that HAP40 can´t be run as hard as REX45 potentially can, cause the former is cladded with SUS410... just parroting here though.
Anyway, I enjoy both very much. Actually my favorite steel(s) overall for PE! (Stainless or non stainless)
BeggarSo
#47
Post by BeggarSo »
Danke wrote:
Fri Nov 28, 2025 1:59 pm
Nah the actual formula starts with CR8 :winking-tongue
BeggarSo
#48
Post by BeggarSo »
Fri Nov 28, 2025 2:05 pm
Oh thats right my HAP40 Delica Wharncliffe does have that stamped on the blade. I didn't know all HAP40 was clad. Thanks.
Danke
#49
Post by Danke »
Many steels are sold under different names like Rex 45 being sold as Hitachi HAP40 or Erasteel 2030.
Source
https://knifesteelnerds.com/2018/11/26/ ... etention2/
#50
3V for general purpose fixed blades.
S7 for high impact tools like choppers.
A2 at a high hardness is a severely underrated steel too. Outclassed by 3V but more expensive too. I'd like to see a 61-62rc A2 Mule.
RustyIron
#51
Post by RustyIron »
K390 is easy to give a spectacular edge, and it holds up well to normal use and minor abuse.
15V seems to be close to K390. I need to give it more time to decide which I like better. It doesn't patinate as readily, so that's a plus.
#52
BeggarSo wrote:
Fri Nov 28, 2025 2:51 pm
I don´t know either if this is really always the case... Just all Spyderco HAP40 blades are cladded, and the few other HAP40 (kitchen-) knives I happen to know of are too.
Danke
#53
Post by Danke »
I think you'll find all the folding Hap40 knives (and all the carbon steel versions) from that maker in Japan will be clad.
BeggarSo
#54
Post by BeggarSo »
What do you all think about REX121?
Wowbagger
#55
Post by Wowbagger »
3V some what near it's full potential ?
I don't even come close to getting this crazy but I remember this vid from way back in the day .
be sure to watch as far as the telephone / power pole .(less than half of vid length) .
Sorry if violating rules .
There was another one where they take a thickish custom knife and using small sledge hammer / blacksmith's hammer the guy cuts off a length of 1/4 inch mild steel plate while plate is clamped vertically in a giant vise . . .a strip a few inched long !
then
are you ready ?
They clamp the knife in a power rack (for weight lifting) and hang a couple or three hundred pounds off the end of the handle . Bends way over ; does not snap off .
Danke
#56
Post by Danke »
BeggarSo wrote:
Sat Nov 29, 2025 5:22 pm
Love it
RustyIron
#57
Post by RustyIron »
Wowbagger wrote:
Sat Nov 29, 2025 6:39 pm
That's the most ridiculous thing I've seen today...
and I had to watch every second.
Motörhead made it even cooler.
Wowbagger
#58
Post by Wowbagger »
I bow down to it ! ! !
It is kind of on the opposite end of the scale from 3V ; can snap it off no problem but would probably shave curls off a decently heat treated 3V blade . . . it certainly cuts glass bottles !
I . . . (and I am not lying , exaggerating or trying to build myself up ) . . . ENJOYED my first try at reprofiling and sharpening it to polished / whittling edge .
WITH DIAMONDS it was a breeze / much easier than I expected .
Incredible what Spyderco has done with REX 121 ! ! !
and on the first try !
If you like high wear alloys , if you are used to using diamond sharpening media : YOU MUST TRY IT !
BeggarSo
#59
Post by BeggarSo »
I have moved away from diamond media, Spyderco's Gauntlet with CBN rods changed my prefferences when they came out.
I dont know why CBN works the way it does I just know I like the results.
Yes some can sharpen with a brick thos folks are exceptional for sure, I ain't one of em.😀
Hmm looking up REX121
BeggarSo
#60
Post by BeggarSo »
Was the sage 5 the only REX121 knife made? I dont see any other spyderco models.
