I carried this Ladybug on my keys for 3 weeks and this was the result.
My keys hang from a steel ring on my belt, so they're not in my pocket close to body moisture. Where I work gets around 100 degrees in the summer and stays at a very high humidity. Even though I spend 90% of my day inside an air conditioned office, just walking out into that hot/humid air was enough to cause this rust. AND this is after drowning the whole knife in Tuf-Glide. The only thing I've ever cut with this knife was pepperoni and only on one occasion, which you'd think being as greasy as it is would do more to help prevent corrosion than cause it. Maybe that's what caused this, I did wipe it clean afterwards but I didn't reapply Tuf-Glide.
Personally this really doesn't bother me much, as long as the pivot stays clean I can polish off most of this rust. What bothers me more is how corrosion will also dull your edge so if I continue carrying this one I'd want to touch up the edge more regularly.
To be fair to K390, I had the same thing happen to a ZDP Ladybug, though not quite as bad and nowhere near as fast.
