Catcherman LC200N, Green Handle
Sems to have disapeared from the line-up. Just wondering what happened???
- John
"Spyderco"...Vēnērunt, vīdērunt, vīcērunt
Re: Catcherman LC200N, Green Handle
It was a Sprint Run, just the one limited production run was made.
It was a sprint run... the batch that was produced are all that will be made.
MNOSD member #0035
MNOSD member #0035
Got it, thank you!
- John
I have one as a collector piece. But as far as using a Catcherman with H-1 blade steel I like the MBS-26 and AUS-8 blades much better for serious work.
I would love to see another rendition of the Catcherman with one of the newer steels. As much good luck as I've had with Cruwear I think that a Cruwear Catcherman would make for a great Sprint Run. But I would want to see it available in full SE just like the older AUS-8 version was.
A full SE Cruwear Catcherman?!JD Spydo wrote: ↑Sat Dec 07, 2024 4:34 amI have one as a collector piece. But as far as using a Catcherman with H-1 blade steel I like the MBS-26 and AUS-8 blades much better for serious work.
How is it that you know what I want before I know it myself? Are you from the future?!
- Al
Home: Chap LW SE.
Currently searching for:
Ayoob SE Cruwear
GB2 Cruwear
Home: Chap LW SE.
Ayoob SE Cruwear
GB2 Cruwear
