Cru Wear Centofante III !
Flash
Re: Cru Wear Centofante III !
#41
Post by Flash »
The hollow-grind combined with a premium steel and thin blade stock would have made a great case for itself being a proper high performance model that many of us been craving from Spyderco.
If it is indeed a flat-sabre grind it is simply no longer particularly appealing for me, and to be honest very easy to pass up on at that ridiculous asking price.
I see a Flat-sabre replacing the hollow grind as nothing more than a cost cutting measure.
miohin
#42
Post by miohin »
The Centofante 3 has been on my list of knives I'm interested in but the price for this version about knocked me out of me chair.
It will be a pass for me just on that front.
Lurker
Buddafucco
#43
Post by Buddafucco »
Meadowlark wrote:
Fri Sep 06, 2024 2:58 pm
It looks like the cf is pinned, right?
Edit: now that I looked again, is this screw construction?
There is a good video on IG of one from nfl_edc_knives. It has Torx heads.
•• Beau
Meadowlark
#44
Post by Meadowlark »
Buddafucco wrote:
Sat Sep 07, 2024 11:14 am
Awesome!
#45
The body screws are but I'm still wondering about the pivot screw/pin underneath the clip.
prndltech
#46
Post by prndltech »
Mine should arrive Monday and if it’s not a hollow grind… I’ll be returning it.
MNOSD 0006
Meadowlark
#47
Evil D wrote:
Sat Sep 07, 2024 3:17 pm
Is the current catalog models pivot pinned? I.e. not adjustable pivot?
#48
the frn centofante 3 & 4 were always fully pinned and drilled for right hand carry only. I haven't heard of any CQI changes to them since I last owned one around 2006.
Meadowlark
#49
Sat Sep 07, 2024 8:16 pm
Was the pivot pinned from both sides, too?
#50
Meadowlark wrote:
Sat Sep 07, 2024 9:22 pm
the only screws on my frn versions of the 3 and 4 were for the clip.
R100
#51
Post by R100 »
prndltech wrote:
Sat Sep 07, 2024 7:59 pm
Please let us know when you get it. This is the key for me too.
Dan
buckleys
#52
Post by buckleys »
R100 wrote:
Sat Sep 07, 2024 10:22 pm
Dan
It's a (saber?) grind. I went to the instagram account mentioned above and watched the video. Like it starts at flat, then becomes a hollow grind halfway through. From what I see the original is like that as well, so yeah it is a hollow grind.
#53
It's 2mm stock. whether its a hollow saber grind like the OG, or a flat saber grind, it'll slice well. Especially if you drop the edge angle down to 10-12dps.
#54
It's hard to tell even in videos but the reflection on the blade sure looks flat. But, the hollow grind on my Ayoob sprints were all way less hollow than my original so it may just be less pronounced. Mine is also due to arrive tomorrow so we'll see.
Enactive
#55
Post by Enactive »
This is an interesting release. Hopefully the pivot is screwed, as would seem likely with the body rivets of yore changed to screws.
Something else I am curious about-- does this model have a kick? My recollection was that the old models didn't have a kick and that in the closed position you could accidentally squeeze the blade so that the edge could contact the lock bar or spring.
prndltech
#56
Post by prndltech »
Dan
Of course… Evil D or someone else might beat me to it though!
MNOSD 0006
#57
prndltech wrote:
Sun Sep 08, 2024 10:11 am
Dan
It'll be evening after work before I get my hands on it :worried
Hopsbreath
#58
Post by Hopsbreath »
Evil D wrote:
Sun Sep 08, 2024 6:38 am
If you’re talking about the sprint Ayoob in Cruwear, those aren’t hollow grinds, they’re saber. I had mine reground to hollow and it was a world of difference.
prndltech
#59
Post by prndltech »
Evil D wrote:
Sun Sep 08, 2024 10:15 am
Same my dude, same.
MNOSD 0006
#60
Hopsbreath wrote:
Sun Sep 08, 2024 3:52 pm
The Cruwear sprint is hollow, however small it may be, I sharpen the back side of mine FLAT on a stone and you can see where scratches are only on the edge and top shoulder of the grind. It may be so small it doesn't matter in performance but you can see it after sharpening the way I am.
