Is a revolver enough?
Post by Doc Dan »
Is a revolver enough gun for concealed carry and defensive requirements? I'm not talking about something like an NAA 22 mag single action revolver, but something like a S&W J Frame or K Frame with a 2 or 3" barrel. I am thinking 327 magnum, 38 special, 9mm, or 357 magnum for calibers. What do you all think?
Most shootings only use 1 to 3 rounds.
A revolver is more reliable than a small pocket semi-auto.
A revolver can be had as light as 12 oz (340g).
A revolver can be more powerful than a pocket semi-auto.
A small revolver is very easily concealed.
Ankerson
Re: Is a revolver enough?
Post by Ankerson »
Why wouldn't it be? :thinking
TomAiello
Post by TomAiello »
A handgun is a disengagement tool. Its purpose is to achieve sufficient stand off to allow you to remove yourself (and your loved ones, if necessary) from a dangerous situation. A revolver is definitely enough for that.
The reliability advantage, especially if you are forced to discharge the weapon in a less than ideal position, is an important point in favor of the revolver.
Have you looked at the Ruger LCR?
MacLaren
Post by MacLaren »
I agree with Jim.
Especially with the ammo available today
But, a good ole 357 magnum with a 158gr jhp will certainly be enough imo
But, look into Underwood Xtreme Defender
I use them in my .357 magnum, .38 spcl
& .45 Automatic
MacLaren
Post by MacLaren »
S&W Model 19-3 w/Underwood Ammo. 38 Special Xtreme Defender
I take this with me every camping trip we have
It or the .45 Auto - but it's usually the 19-3 that goes....
MacLaren
Post by MacLaren »
And, if your worried about ammo capacity- just get a couple speed loaders and practice re-loading
I love a wheel gun. The trigger on this 1977 model 19-3 is just pure bliss.
A revolver is an excellent choice imo
& not trying to be a know it all but, Doc, make sure whatever you get has a good trigger - look for a good used older Smith - just my opinion Doc.
TomAiello
Post by TomAiello »
Underwood makes some really good ammo. It's my first choice for defensive use.
RustyIron
Post by RustyIron »
Doc Dan wrote:
Thu Jun 27, 2024 8:47 am
Yes. Gun guys tend to quibble about capacities, calibers, sights, and holsters, when the biggest obstacle to personal safety is between one's ears.
Unless you're a deep undercover operative being hunted by both the KGB and cartel assassination squads, then a modestly sized gun is likely to suffice.
MacLaren
Post by MacLaren »
RustyIron wrote:
Thu Jun 27, 2024 10:28 am
Man, we've had a BLAST with those Time Life Old West books!!!
Been meaning to thank you again!!
RustyIron
Post by RustyIron »
MacLaren wrote:
Thu Jun 27, 2024 2:23 pm
Your enjoyment is thanks enough.
Glad you're having fun with them.
yablanowitz
Post by yablanowitz »
The sole disadvantage to a revolver lies in concealing the thickness of the cylinder. An automatic of comparable power and capacity will be easier to conceal. If your build and clothing can handle that, revolver is fine.
Post by Doc Dan »
I note that at contact "get off of me!" distance most semi-autos will not fire, but a revolver will. I shoot a semi-auto much better, but that ability to shoot through a coat pocket or at contact cannot be overlooked.
Post by Doc Dan »
TomAiello wrote:
Thu Jun 27, 2024 8:53 am
Yes, I used the Kel-Tec version to successfully defend my life and the lives of others. It worked perfectly. I love the size and weight.
akapennypincher
Post by akapennypincher »
Revolver is enough, hope you never need use for CCW, as if your not charged criminally, and are 110% justified. Your chances of being civilly sued is good, and will cost you money to defend yourself
Tristan_david2001
Post by Tristan_david2001 »
Did Jesus use guns
:bug-red-white:
legOFwhat?
Post by legOFwhat? »
Every good shepherd protects his sheep :winking-tongue
-Larry
MNOSD #0049
MacLaren
Post by MacLaren »
Tristan_david2001 wrote:
Fri Jun 28, 2024 8:27 am
Did Jesus use guns
No sir, be He told us to get a sword.....
MacLaren
Post by MacLaren »
legOFwhat? wrote:
Fri Jun 28, 2024 8:31 am
Amen 🙏
MacLaren
Post by MacLaren »
yablanowitz wrote:
Thu Jun 27, 2024 6:48 pm
That's a great point.
I've never really concealed carries before but, I can certainly see what your saying 😎
yablanowitz
Kansas enacted "Constitutional Carry" a few years ago. Open carry has always been legal here, but not really socially acceptable. Even now, not openly advertising that one is carrying is advisable from a social standpoint. The flatness of an auto is less likely to print through clothing than the bulge of the wheelgun's cylinder.
As for the auto being unable to fire at contact range, wrong. If you are muzzle punching someone hard enough to force the slide out of battery, that will prevent most locked breech pistols from firing, but not straight blowback actions. Firing inside a pocket has a lot of variables involved, and clothing is as likely to snag a revolver's hammer and prevent firing as it is to stop an auto from firing.
