Steeltoez83 testing log
Re: Steeltoez83 testing log
Factory edge was quite dull so I tuned it up. Ended up with 220 on my sanding roll with my HIC mule.
In terms of sharpness, I'd say the material is deceptive. And to the fingerpads it doesn't grip how we are used to with carbides in steel. Even at an 800 grit finish, I'd say draw cutting is the most effective way to evaluate and use. I still prefer steel bcuz it has more grip when cutting across its alloys.
My cut numbers for my zdp 189 endura was 390 from my records.
ZDP-189 is still a favorite. Glad you are keeping it in your testing.
156 cuts followed by 78 chops on ice, then another 81 cuts to get 315 out of 390. Roughly an 81% efficiency rating. I have to mention that this knife was gifted to me by kurt for testing purposes.
The HIC mule wasn't able to pass day 2. After day 1 it was fine, but after day 2 it failed. It was still technically sharper at this point than when I received it. 2 days out of the benchmark 7 is a lot more brittle than I'd like to see. I'm deciding if it's the best course of action to do chops on a harder material next or not. Damage wise, not much but if I move to hitting a block of limestone, I might not able to do other testing.
400 grit cbn stone used for 3 minutes on my HIC mule. I expected it to exaggerate damage from the ice whacks but it didn't. It could be the damage was so small it just avoided it all together.
- Brock O Lee
@Steeltoez83 or @Giygas, would you kindly share the YT channel?
Here's his channel:Brock O Lee wrote: ↑Sun May 05, 2024 3:51 pm@Steeltoez83 or @Giygas, would you kindly share the YT channel?
https://youtube.com/@steeltoez8345
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
- Brock O Lee
Thank you!Giygas wrote: ↑Sun May 05, 2024 4:31 pmHere's his channel:Brock O Lee wrote: ↑Sun May 05, 2024 3:51 pm@Steeltoez83 or @Giygas, would you kindly share the YT channel?
This week I'm testing an obvious clone of the buck 110 in 8cr13mov. I saw this at my local hardware store for 20 dollars. I haven't listed any spyderco 8cr testing results in this thread, so it should be a fun comparison. Build quality is very poor on the clone. Factory edge scored 35, 1st edge 70.
Spyderco leafjumper in k390. One of my favorite carry knives. I have cut tested seki k390 before, but nothing for this thread. 475 is right where my stretch and delica tested before.
Got around to testing the buck clone and the leafjumper. I goofed on the 2nd edge of the clone, but the 3rd edge confirmed the 1st edge. At 40% of 70 I did 28 slices, followed by 14 chops on ice to reach 60% It passed, so I did 5 more slices and it failed at 47. In sharpening it sounds like a squeaky door hinge on the stone.
Leafjumper in k390 also passed the 60% benchmark. I spent some time searching the tube for reviews of this knife, and other tests of k390 from seki. As I have stated before, the LJ and the 100 pacer are hands down my favorite spydies. I think the LJ is such a sleeper knife in spydercos current lineup. 190 slices, 95 ice chops, and it still passed. After 75 more slices it failed. 360 out of 475 is an efficiency of 76%.
