Military 2 Discussion (Merged)
ZrowsN1s
Re: Military 2 Discussion (Merged)
#981
Post by ZrowsN1s »
hplovecrafter wrote:
Sun Apr 28, 2024 9:25 am
hello everyone. I'm brand new to Spyderco and to the forum, and I just purchased a Military 2 in Crucarta. I want to put a black pocket clip on it, and I'm not doing well with the "Search" function on the forum so I apologize if this is in the wrong spot....but can anyone tell me which pocket clips will be compatible with the M2?
I got my first Military 2 (satin/S30V) three days ago and LOVE IT but I just don't like shiny pocket clips..so if anyone can tell me if the PM2 clips fit it or any others I'd really appreciate it. many thanks
Yep, the PM2 and Para 3 Clips will fit the Military2. LynchNW, Ripps Garage Tech, and a few others make aftermarket clips as well. If you order aftermarket, just make sure you're getting clips for Military 2 not Military(1). They are different.
hplovecrafter
#982
Post by hplovecrafter »
Michael Janich wrote:
Mon Apr 29, 2024 6:57 am
Dear hplovecrafter:
Yes, the Para Military 2 clip is the same as the one used on the Military 2.
Stay safe,
Mike
thanks! I'm getting your YoJumbo soon, too. appreciate the welcome, and the help
EDITED TO ADD: also many thanks to Matt on the clip recommendations
Last edited by hplovecrafter on Mon Apr 29, 2024 10:28 am, edited 1 time in total.
marrenmiller
#983
Post by marrenmiller »
I don't post much here (usually on Reddit/BF), but I figured I would share my experience with the latest drop as this thread is more active.
I got my Crucarta Military 2 in on Saturday, and it was a little rough out of the box. The lock bar is noticeably more stiff than on any PM2 I own or have owned before, the centering was very off towards the show side scale, one of the clip screws was stripped and free spinning, and the action was not smooth. The electrical fire smell is also a bit odd and is not something I've experienced before, having owned a Crucarta Shaman.
I took it apart and found the same laser cutting remnant/burr on the pivot hole as noted earlier. It popped off after I hit it with a diamond file. I have adjusted the action the best I can and loctited the screws down, but the pivot tightness keeps loosening as I break the knife in so I'll probably need to redo this again. I cannot fix the centering with the usual body screws/paper wedge trick, as the blade will wander back in a short time.
The pocket clip screws/threads are perplexing, as the threading on one of the pocket clips screws was totally wrecked out of the box (popped out when I went to change the clip to tip-up, as it wasn't held in by anything other than friction, and the threads are just completely gone). Even with the other two clip screws, neither want to go cleanly into the threaded holes in the liners, and none of the screws seem quite long enough to make it to the inner liner surface. I've never seen these issues before with a Spyderco. Eventually I subbed in a clip screw from a Manix 2, so now I've got a T8 along with two T6s holding my clip on.
Not off to a great start, but I'm hoping I can eventually get it into a better state. I'm kinda irked with myself for messing with it when I should have just returned it for a replacement.
ErikLee
#984
Post by ErikLee »
I just ordered a Crucarta PM2 and can't wait to get it in my pocket where it belongs.
I want to get some aftermarket scales for the thing to make it my own, but as the liners are different than all other PM2s, I'm wondering if anyone has some links to stores that sell aftermarket scales for this unit and are located in Europe, I would be all ears.
BLADE_OCD
#985
Post by BLADE_OCD »
Good evening, gents,
While I don't post here often, I recently stumbled upon an incredible knife—the MILITARY 2 BLACK G-10 BLACK BLADE C36GBK2—that I believe deserves more attention. Today, I received this knife, and it truly is a remarkable work of art. This marks my fifth Spyderco acquisition in just four months, and it might be my last.
If you're hesitant about purchasing this knife and happen to come across this post, I urge you to give it a try. Despite its similarities to the Para Military 2, it's not significantly larger and the ergonomics are amazing. Personally, I prefer it over my CRUCARTA Para Military 2, although the PM2 did feel noticeably sharper out of the box. This thing is awesome. Please give it a try if you can. Thanks.
ErikLee
#986
Post by ErikLee »
BLADE_OCD wrote:
Fri May 03, 2024 4:19 pm
I heard some rumors that the Military 2 will get the same Salt treatment as the PM2 has had, Magnacut, G10 and black DLC. Also Eric mentioned at a recent blade show that they are optimizing the DLC process, which should be in production by the end of the year. I expect the new Military 2 will come in that full blacked out version, which is the knife I will be waiting for myself.
Magnacut being better in almost every aspect as S30V, except, perhaps, for edge retention.
BLADE_OCD
#987
Post by BLADE_OCD »
ErikLee wrote:
Wed May 15, 2024 1:01 am
ErikLee,
Thanks for the reply. The Military 2 is now my daily carry. I would buy another if they came out with a salt version like you mentioned but it would need to be fully serrated. I think I need some full SE knifes in my life. Thanks.
#988
The Cruwear M2 has landed on my doorstep. My example is pretty much perfect... 🎯
I've already put it to work, but I'm keeping it tip-down for now while I form an opinion.
James Y
#989
Post by James Y »
I would love to have a Salt version of the Military 2, but I probably won't be getting one even after they become available. I would if the scales had the same texture as the standard G10, but I'm pretty certain that the Salt Military 2's scales will be textured just like the PM2 Salt's, with the clip's contact point on some pocket-shredding spot.
ErikLee
#990
Post by ErikLee »
Sal or Eric, would it be a realistic assumpion that we can expect a Magnacut Sslt version of the Military 2 using the "DLC" coating that was mentioned at the recent SHOT show?
And the point James mentioned about the Salt scale texture being a pocket shredder, why not smoothen a line into the scale at the pocket clip contact points? Design wise I think that would not at all negatively impact the design language of the Salt scales.
SAF-1
#991
Post by SAF-1 »
Speaking about the Fully Serrated Version!! Where is it ??? I ordered one almost a year ago!! What gives ?? Why Soooooo…. Long ??
#992
I tried tip down for a few days, because I prefer that on the M1. I noticed however that the M2 clip sits about 1.5mm higher/more proud above the scales compared to the M1's broad flat curved clip. As a result, for me it was not as comfortable tip down as the M1, so I changed to tip up. So far so good… It feels even more like a PM2 XL in this orientation… 🙂
Sanding/chamfering the edges of the micarta made a noticeable difference to the hand comfort. It is comparable now to the M1's chamfered scales. Give it a go…
wrdwrght
#993
Post by wrdwrght »
Brock O Lee wrote:
Tue May 21, 2024 12:17 am
There I was, nicely balanced on the fence, then you, Hans, had to invite me to give it a go…
Next week, I imagine I’ll also be chamfering mine, too.
#994
wrdwrght wrote:
Wed May 22, 2024 3:24 pm
Guilty as charged Marc... 😂 😇
This is not the first time I've smoothed corners on scales, but I want to credit (not blame!) Jeff for this idea on his blue micarta PM2.
JSumm wrote:
Sun May 19, 2024 2:44 pm
DIY chamfering goes along way with this one.
I somehow made up my mind that the micarta slabs on the PM2 and M2 are too thin to chamfer. I was wrong, and I think it is worth doing. 👍
#995
Brock O Lee wrote:
Wed May 22, 2024 9:47 pm
I've done it twice now on my Crucarta model and looking at it, I still think I should have been more aggressive and gone further. I think the AWT PM2 scales are a good example of what it would feel like if you get real aggressive with it. And those feel awesome!
brj
#996
Post by brj »
Got one of them Para2XLs people are talking about ;)
Ain't no Millie, but not entirely bad either.
#997
I want to see a new M2 with at least a 4" blade in Maxamet. Carbon fiber scales... I would be in for more than a couple of them. Those would make great gifts to guys I know.
Those of you with the clip screws loose and or stripped, the three screws they have been using only go through about half the thickness of the liner.
Therefore some have had the threads pulled over, or basically stripped. They need a longer screw length.
I don't carry my knives tip down, so I just ran into this issue with my new M2 in Micarta, not knowing what thread size these screws actually are, I reluctantly just returned it for warranty.
I always fix all that stuff myself, so my first time warranty repair lol... Heck I am 66 years old and a serious gearhead and will dive head first into really serious troubles lol.
I will also say for you guys changing the clip to tip up on these, make sure to inspect the threads on the very end of those screws...
They look like they are stripped or rolled over much at all, don't try using them to reposition to tip up, as those jacked up screws will not hold the clip and more than likely strip out those threads in your liner... Just say'n what I have seen.
#998
brj wrote:
Mon Jun 03, 2024 4:19 am
Yep, cool that people now can have a PM2 XL... and someday we´ll perhaps also see a Military 2... ;) :zany
#999
Mon Jun 03, 2024 6:31 am
We already have a Military 2.
The next step now will have to be a PM2 XL Linerlock… :zany
Capt'n Boatsalot
#1000
Post by Capt'n Boatsalot »
This is about where I'm at. Really nice knife, but hasn't mind-melded with me like the OG Military did. The astounding size-to-weight ratio of the original has always really impressed me. My Military 2 is the CruCarta version, and while I understand the need for non-nested liners, I definitely prefer them nested. It's just a cleaner look, and further cuts weight.
I will say that the micarta on the CruCarta is sublime in hand. So soft and grippy. Love it.
I'm sure with time I'll develop more fondness for the new one, but right now I'm all in on the original.
MNOSD member 0030
