Four!!!! Hole in 1, 4Max? Ti Max?
Fireman
Post by Fireman »
Thinking about running the four max elite with titanium liners and hardware without the scales and adding a hole where the thumb stud is. What do you think? Here is a mock up.
:winking-tongue Mule Team Army 001
MNOSD 008 :usflag
Image Stable Mules; Z-Max, Z-Wear, Magna Cut, SRS13, Rex 76, Rex T15.
Naperville
Re: Four!!!! Hole in 1, 4Max? Ti Max?
Post by Naperville »
Might work. I like the model too...
I'll be watching to hear how the spydie hole mod works.
:unicorn
Naperville
I like the stainless, but there is always the option of using 3M grip tape for one side. I'm thinking about buying some for my knives.
https://www.3m.com/3M/en_US/p/c/tapes/anti-slip-grip/
RustyIron
Post by RustyIron »
Mon Dec 11, 2023 9:41 pm
Right on.
If Fireman has laser or EDM capabilities, it might be pretty easy.
The best I could do would be a carbide fly cutter with a lot of coolant, and my expectation would be an ugly hole and damaged tools.
Fireman
Post by Fireman »
I used diamond bits in my Makita to do this hole in the Mayhem. I modded it quite a bit.
MNOSD 008 :usflag
Fireman wrote:
Mon Dec 11, 2023 11:29 pm
In a Makita hand drill?
And what kind of diamond bit, may I ask?
RustyIron
Post by RustyIron »
From where I sit, that looks like a clean, round hole.
Nice work!
riclaw
Post by riclaw »
Mayhem looks real nice. Good job, Fireman!
- Richard
Fireman
Post by Fireman »
Bolster wrote:
Mon Dec 11, 2023 11:38 pm
6mm shank diamond bits in my Makita hand drill.
MNOSD 008 :usflag
Fireman wrote:
Tue Dec 12, 2023 10:54 am
...6mm shank diamond bits in my Makita hand drill...
Well I'm gobsmacked! I did not know you could do that kind of work on hard steel with a hand drill!
Fireman
Post by Fireman »
Took about an hour
Look at this for tips but I did fine with a hand drill.
MNOSD 008 :usflag
Fireman
Post by Fireman »
Here is a start. Probably make it a bit bigger
MNOSD 008 :usflag
Dude in the video uses a carbide bit to roughly enlarge the hole. I assume diamond bit works as well, maybe better?
Fireman
Post by Fireman »
I haven’t used carbide, but diamond seems to work. OK just takes a while and dirty. I also used diamond files
MNOSD 008 :usflag
Fireman
Post by Fireman »
Well she is about 95% the way there. She is a butter knife right now (Butter face😂) Had to alter and or shorten all the hardware to make it work but it now carries like a dream and you don’t feel like you are carrying such a huge knife. I will probably do some satin finish and or some flame design since the scales are Titanium. Voila! Kind of industrial minimalist.
MNOSD 008 :usflag
RustyIron
Post by RustyIron »
That's NICE! Holes are the way to go. Post pictures of the colors you create.
lookin good! think you'll contour the scales some or leave them as is? how's the opening arc for the hole? does the guard get in your way at all?
:unicorn
Fireman
Post by Fireman »
Fri Dec 15, 2023 7:25 am
The guard was getting in the way little bit so I took some off. I’m just leaving the liners without scales. Opening ark is great
MNOSD 008 :usflag
Fireman wrote:
Fri Dec 15, 2023 10:18 am
I had a feeling that would be the case. I'd love to mod some of my CS folders with opening holes. The studs work but they're not nearly as good as the spyder hole.
:unicorn
