Decision time what to purchase, don’t say by both
Re: Decision time what to purchase, don’t say by both
I prefer the regular Manix II over the XL but I don't have Gorilla hands like vivi
Pick neither, if you really need others to guide you.
I have medium hands. definitely the XL. I hate how the regular feels like trying to hold a fish, with my hand slipping off the back. It needs much less of a heel drop. The XL has no such problem.
AHAB
My solution to this problem:
viewtopic.php?t=94703
AHAB
- apollo
Would go crazy for that aswel especialy if they would cave in and trow in the powerlock...
Nice sketch. Do we know if the choil is necessary to clear the CBBL mechanism when closed?
- Manixguy@1994
Excellent question ! Dan
Manixguy@1994 wrote: ↑Thu Nov 02, 2023 9:27 amExcellent question ! Dan
It's still difficult to tell even with this photo, but it looks like the lock area would be pretty crowded without the choil...what do you think? Do you think the edge could clear the lock with a tweak here or there?
- Manixguy@1994
I have to agree looks very tight and may possibly hamper the spring ? Pure guesswork on my part , but think little room for error . Really above my pay grade . Thank you Bolster . Dan
Manixguy@1994 wrote: ↑Thu Nov 02, 2023 9:03 pmI have to agree looks very tight and may possibly hamper the spring ? Pure guesswork on my part , but think little room for error . Really above my pay grade . Thank you Bolster . Dan
I´ve brought this up quite often already (if a CBBL requires a choil and/or tall handle), but still I don´t have a definitive answer...
The P´kal actually features a BBL (so not caged, but otherwise similar to a CBBL) and has no choil - but then (look at the pic below) when the knife is closed, the blade seems to sit unusually far "forward", so appearantly is not interfering much with the lock by doing so ?! (Can´t really tell from the pic)
And one could probably make the lock a bit smaller? Or position it differently?
Good idea. The Modacious? The Bonix? "Bodanix" sounds like medication for acid reflux.
Manix 2, the standard version, gets my vote. Better size, in my personal opinion, for daily carry and use.
MNOSD member #0035
MNOSD member #0035
The definitive answer you're looking for is - No, the CBBL does not require a choil or “tall handle.”Wartstein wrote: ↑Fri Nov 03, 2023 1:15 amManixguy@1994 wrote: ↑Thu Nov 02, 2023 9:03 pmI have to agree looks very tight and may possibly hamper the spring ? Pure guesswork on my part , but think little room for error . Really above my pay grade . Thank you Bolster . Dan
There are certain design requirements because of how the lock mechanism is positioned in-line with the blade though. In a similar sense to how a backlock has certain design requirements for the same reason.
Also, the “Ball Bearing Lock” and “Closed Ball Bearing Lock” are the same lock mechanism but the latter just encloses the ball bearing with a plastic cage for better grip. I understand the description for the P’Kal Trainer states it uses the Ball Bearing Lock but as we can see, it is in fact the Closed Ball Bearing lock.
I believe a choil-less Manix is perfectly within the realm of possibility for Spyderco but whether I believe it to be a necessity or not, is another story.
Akapennypincher - this is the knife you want!
Not going to lie, that’s a badass looking knife!
- akapennypincher
- akapennypincher
akapennypincher wrote: ↑Fri Nov 03, 2023 7:06 am
Well the question was asked as I am on fence about the XL, but was considering it, but. Sometimes asking an owners specific question is productive, as they have experience with product as they have owned.
- Manixguy@1994
akapennypincher wrote: ↑Fri Nov 03, 2023 7:08 amThe Manix XL is a favorite of mine but it may not be for everybody . Great HD knife and have carried since first run in lockback since they came out . I find them to be confidence inspiring in hand and versatile enough to do many jobs. The downside is size in pocket , they are a pocket hog but I only carry a knife in my main pocket so not an issue for me . Hope this helps . MG2akapennypincher wrote: ↑Fri Nov 03, 2023 7:06 am
I can only compare the Manix 2 and C95P (Backlock Manix). Honestly if the grind is similar as the original on the XL, well you get more blade but with a similar behind the edge thickness as the Manix 2. More is better in my opinion !
Problem is, our opinions can't really tell much about your opinions
Both are excellent, just ask yourself if you prefer a bigger blade or not.
C95P in picture just below :
MNOSD member 004* aka Mr. N5s
If your hand fits in the XL handle, it'll also fit fine on the Manix 2. That said, I picked the Manix 2 a long time ago.
- BEER_IS_COOL
I own several Manix's and love them.
However, I am in a phase of carrying bigger knives at the moment and don't own an XL... so I'd probably pick the XL right now lol.
- Buddafucco
I have both.
If I was stranded on a desert island and had to choose one... I'd pick the XL.
If I was not stranded on a desert island... I would rather keep the regular Manix2.
•• Beau
