Polliwog mini-review/first impressions
dsvirsky
Poliwog mini-review/first impressions
Post by dsvirsky »
Got my new Poliwog yesterday (from NGK). Overall, I was very impressed. Fit and finish on this knife are as good as on any production knife I've ever owned. The tolerances on this knife are so close that it's almost superfluous to state that the blade is perfectly centered when closed because if the blade wasn’t centered, it would rub – it is barely possible to slide a thin piece of paper between the blade and the frame on either side.
Blade grinds, including the swedge, are centered on the blade and even, at least to the eye. The closest I can come to criticizing the grinds would be an observation that one side of the swedge makes a slightly straighter line to the point than the other. The knife came Spydie sharp, as expected.
Lock-up is, of course, rock solid. This is really my first experience with the ball bearing lock and I was somewhat surprised at how quietly the lock operates. The ball bearing also holds the blade closed quite nicely, although it doesn’t “suck” the blade back in if opened slightly; this may improve with use, given that the knife is currently not quite as smooth on closing as it is on opening.
All the edges on the handle are rounded and I find the Poliwog very comfortable my hand; however, this is definitely a YMMV situation, since the Native just doesn’t fit my hand right and most people seem to like the Native. One of the things that’s really nice about this knife is that you get a full-handed grip on a small knife, without the handle/blade ratio appearing disproportionate. At just over 4 ounces, it’s heavy for a small knife and my first thought was that Spyderco needed to make this knife in titanium to cut the weight. However, doing so would change the balance of the knife. Currently, the balance point is behind the pivot at the middle finger groove and it’s not a bad thing for a small knife to be a bit handle heavy (as Rob Simonich pointed out, this way it tends to stay in your hand).
All in all, I'd say that Spyderco has produced a winner here.
Michael Cook
Post by Michael Cook »
:spyder: I covet that knife. :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
Mr Blonde
Post by Mr Blonde »
I too must have this knife!!! :D
Thanks for the review!
Wouter
Last website update: 10-31-2025 Instagram
Nicky
Post by Nicky »
Is the poliwog easy to flip open? I need to know since customs borders haven't harass me for more then a month and I'm expecting a big come back.
Thx for the review!
The social revolution is now a fact. As I've discover, I'm a proteiform. The only question that remain unclear is; Who are you?
FRIZ
Post by FRIZ »
Hi dsvirsky:
Thank you for the review. :)
Regards,
FRIZ
smcfalls13
Post by smcfalls13 »
Thanks for the review, I've been looking at a Poliwog, but I wasn't sure if I liked it enough to replace my Dodo.
:spyder: Scott :spyder:
"We make a living by what we get, we make a life by what we give."
-Sir Winston Churchill-
greencobra
Post by greencobra »
Good review. I'll be needing to get one too. Enjoy it.
Avatar by Dialex
jaislandboy
Post by jaislandboy »
Nice review Dsvirsky, enjoyed reading it!
brian
Dr. Snubnose
Post by Dr. Snubnose »
Thanks for the review...I knew I had to get one more...just forgot which one...thanks for reminding me...Doc :D
spydutch
Post by spydutch »
Thanks for the review. Just a pity it doesn't come serrated, but I'm practically sure I want to have this knife anyway..
dsvirsky
Post by dsvirsky »
Nicky wrote:Is the poliwog easy to flip open? I need to know since customs borders haven't harass me for more then a month and I'm expecting a big come back.
I would say that the Poliwog would be very, very difficult to flip open. But then, I would have said the same thing about the Calypso Jr. lightweight and, from what I understand, Canadian customs has managed to confiscate at least one of them on the basis that it's a "gravity knife."
VWTattoo
Post by VWTattoo »
Very nice review! Makes me want a Poliwog, and I don't really like it, for some reason. Thanks for writing such a well worded review of your new knife, dsvirsky!
2004 VW R32 :cool:
Got GIN-1?
Daniel
Post by Daniel »
Great review! I can't wait to get mine!! :)
dialex
Post by dialex »
Thanks for the review of this interesting (to say the least) :rolleyes: knife.
Stevie Ray
Post by Stevie Ray »
Thx for the review!
Hi Nicky. Mine just came in today and I can flip it open. Not a problem. It is a neat little knife and whoever said the tolerences are close sure called that one right. It's put together like a Swiss watch. Nice .. :)
Steve
Zwaplat
Post by Zwaplat »
No pics yet ? :(
testmonket
Post by testmonket »
I have to say, the poliwog sure is an interesting knife. With the Dodo being one of my favorites, I'm excited about the chance to get to handle one of them.
My only real concern is that it is really broad at the pivot end when closed and the indentations are so exposed. I can see a keyring catching in the notches if I were trying to pull my keys out of my pocket.
Has anything like this been a problem? Does the broad end seem to take up a lot of pocket space? I guess the knife is really pretty small, but it's hard to judge on the web.
