Dying Black G10 Scales to Make Them Blacker
Has anyone tried adding more black to black G10 scales to make them even blacker? I have some 'Black 3.0' paint that I know can be used to dye clothing - I was thinking about using it to dye a pair of PM2 black G10 scales.
Re: Dying Black G10 Scales to Make Them Blacker
Is your knife maybe a little dried out? Sometimes G10 can get a chalky appearance to it that you can get rid of with a little oil or even hand lotion. Maybe try that before you dye it and see if that doesn't get what you want. If you still feel you need to dye it afterwards, make sure you scrub them with dish soap and a nail brush to clean off all the oils before you dye them.
- Mr Blonde
This is a great tip. On some of the older G10 handles in my collection, I'll add a little WD40 to get rid of the chalky appearance and the colors (including black) 'pop' again.Evil D wrote: ↑Fri May 05, 2023 1:55 amIs your knife maybe a little dried out? Sometimes G10 can get a chalky appearance to it that you can get rid of with a little oil or even hand lotion. Maybe try that before you dye it and see if that doesn't get what you want. If you still feel you need to dye it afterwards, make sure you scrub them with dish soap and a nail brush to clean off all the oils before you dye them.
Beard oil works too, just pick a scent you like.
- Richard
- Manixguy@1994
Just remember a little oil goes a long way ! MG2
If you do it, please post many pictures!
Thanks all. That's a good tip regarding the oil - I have done that with '3 in one' and also mineral oil, and both work really well. These are the only 'non shiny' black G10 scales I have, so I thought they were at their best - not really chalky or dry-looking. But I will try the oil on them.
My non-reflective black paint is the stuff created by Stuart Semple. I did a painting using it, and the results were close to startling.
Edited to add: I used the silicone WD40 on the scales and nothing really changed, so they were already in their intended state.
But I found a guinea pig for my 'super black' experiment - a Rat 2 scale will be dyed in a little while, leaving one alone, for comparison. Results later today.
Ballistol.
Recent favourites: Massad Ayoob CPM CRU-WEAR PE & SE, Yojimbo 2, Lil' Temperance 3.
Ballistol is great stuff, I use it for gun maintenance and as knife pivot lube. Just a warning though, some people cannot abide by the smell! In small quantities it seems to dissipate quickly, but just be aware it may have an unpleasant odor.
-- Old Norse proverb
I love the smell of Ballistol in the morning, it smells like Victory!!
Dave
USAF Retired
USAF Retired
I also like the smell of Ballistol - reminds me of cleaning revolvers.
I tried dying a Rat 2 scale in BLK 3 and it did nothing.
I used silicon WD40 on my black PM2 scales and the edges got lighter
I used Mineral Oil on the black PM2 scales and they now look fantastic.
My project is almost complete - just waiting for Mr. Postman to bring me my clip.
How did they turn out?
Dear Low_rez:
Stay safe,
Mike
Stay safe,
Mike
- legOFwhat?
-Larry
MNOSD #0049
MNOSD #0049
- chronovore
WD40, 3-IN-ONE, and some other products are at least slightly toxic. While it probably won't hurt you in isolation, why lean into the punch? Most of us have enough toxic exposure in our lives. Just get some pure non-toxic mineral oil from the pharmacy. (You know, the kind you can take as a laxative.) A single bottle is very cheap and can last for many years if only used on knives. I lean the bottle and dip a Q-tip for application.
For dry G-10, first make sure the surface is clean. (This also includes G-10 that is dried out or "white" after cleaning with concentrated alcohol.) Dab a few spots with the Q-tip and then vigorously rub it into the scales with a clean cloth or cotton ball. I prefer a cotton ball because generating a little heat from friction helps it to absorb. It shouldn't take long to get the hang of it. If too much is applied and the surface feels tacky, wiping it with a little vodka on a cloth will often take it down just enough.
You can apply it the same way as a protectant for liners or blade surfaces. Just dab it and rub it to a fine coat with a clean cloth or cotton ball. While you can use this oil on the action, I prefer a thinner oil for moving parts. So I'll generally leave contact spots and their immediate proximity dry during this step. Something like the non-toxic Lubriplate FMO-350-AW (also sold as Lubriplate Gun Oil) is excellent on knife actions.
- Naperville
Hoppes #9 or Bust!
Mr Blonde wrote: ↑Fri May 05, 2023 2:26 amThis is a great tip. On some of the older G10 handles in my collection, I'll add a little WD40 to get rid of the chalky appearance and the colors (including black) 'pop' again.Evil D wrote: ↑Fri May 05, 2023 1:55 amIs your knife maybe a little dried out? Sometimes G10 can get a chalky appearance to it that you can get rid of with a little oil or even hand lotion. Maybe try that before you dye it and see if that doesn't get what you want. If you still feel you need to dye it afterwards, make sure you scrub them with dish soap and a nail brush to clean off all the oils before you dye them.
Common occurrence when you’ve stored a knife with G-10 scales for years. You look at them after many years and wonder how dust got in there even though it’s wrapped in nylon. It’s not dust or dirt or sand but the drying effect and more visible with darker colors of G-10.
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
