Stretch 2 XL Cru-Wear vs Ayoob Cru-Wear
resonanzmacher
Post by resonanzmacher »
Just got my Stretch 2 XL in. Bought it on the strength of the similarities to the Ayoob, which I absolutely love. And they are indeed very similar.
Obv both knives have satined Cru-Wear and gray G-10, stout metal spacing, 4 position clips, lanyard hole, back lock with Boye dent, threaded post construction. Both appear to be washerless although both have flawless action for backlocks. Blade stock is same thickness for both. They appear to be using the same hardware, too.
Differences, aside from the obvious geometry differences like full flat vs saber, downward canted blade vs straight on blade, the Ayoob having a blackened clip, and so on:
1) The Stretch 2 XL is about .25mm thicker in the handle. Hard to see it in pics, you need the calipers.
2) The bevel on the G-10, which goes all the way down to the metal on the Ayoob, only goes halfway down the side of the G-10 on the Stretch. Very similar handfeel although I think I might prefer the full bevel on the Ayoob a little more for my own grip.
3) The liners of the Ayoob are milled and relieved a bit. The Stretch liners do not appear to be similarly milled.
4) The Stretch 2 XL is about 8 grams lighter than the Ayoob despite being a skosh thicker. Maybe down to the full flat grind? Anyway Stretch is~130g and Ayoob is ~138g.
5) Although the cant on the Ayoob blade makes apples to apples comparisons difficult, the Stretch 2 XL is a little longer. It's clocking in just under 4 inches measuring the distance from the tip to the middle of the end of the handle. The Ayoob is more like 3 3/4 inches.
6) The Stretch 2 XL was also a little slicier out of the box, possibly because the Ayoob has that saber grind and is a little thicker behind the edge.
7) The lanyard hole on the Ayoob isn't sleeved. The one on the Stretch is.
8) The action on the Ayoob is juuuuust a little more refined. Both blades can easily be Spydieflicked or thumbed open one handed, and both blades are set up so that they're easy to shut one handed. If you leave your finger in the groove as you drop the blade, neither knife will get you with the edge that way.
My initial verdict is that both knives are outstanding. The different blade geometries make for a very different cutting experience, but they're both excellent at separating matter. The Stretch obv. costs some more money -- and you do get a little lighter and longer of a knife for that, but it's a significant premium. The Ayoob is definitely more idiosyncratic and defensively optimized -- the Stretch 2 XL is more of a general carry knife. But I'm pretty confident in saying that if you love the way the Cru-Wear Ayoob is made you will be a pretty big fan of the Stretch 2 XL in Cru-Wear too.
Anyway here's some pics to compare the two:
Re: Stretch 2 XL Cru-Wear vs Ayoob Cru-Wear
Nice write up and pictures. I hope the Seki GrayWear releases continue!
I have both and was making notations yesterday and discussed privately with another Forum member . You did a great job . One thing I also noticed the finish of the Ayoob is more refined than the XL but not a deal breaker in my opinion , just different . I also have to wholeheartedly agree I hope the Gray theme continues into another model that everyone can enjoy . Regards MG2
Bemo
Post by Bemo »
Interesting similarities, especially if they are from different factories.
Post by JD Spydo »
I haven't yet had the chance to test drive the Cruwear Stretch. But my love for the Cruwear Ayoob model is intense. At this point I sincerely doubt if any new Spyder could make me part with the new Ayoob Sprint Run.
But do keep in mind that even the original VG-10 version of the Ayoob has been one of my top 5 favorite Spyders for quite some time now. For all of you who like the STRETCH model better then more power to you. But for me it isn't even close and I have owned and used other STRETCH models in the past.
PeanutButterFan
Post by PeanutButterFan »
I also have both and have disassembled them. While fit and finnish is good on both, i can tell that the factory from which the Ayoob came pays more attention to the little details. For example, on the stretch and all other seki city backlocks they leave the inside of the knife unfinished. The backspacer and lockbar look rough from the inside. On the ayoob everything is polished on the inside as it is on the outside. It’s disappointing that given its much higher price than the ayoob, the stretch falls short in this area. But I am picking at nits!
The extra milling on the ayoob liners impressed me as well. They made it so the whole tang of the blade will not rub and show scratches from opening and closing.
So for me, the ayboob is a way better value but over all the stretch is still my favorite
i really wanted an ayoob in my collection and i like it, but i think the stretch is the better knife and i would probably like it more from a practical standpoint. that's not to say the ayoob isn't a good knife or that i regret buying it... the ayoob just has a different appeal to me than the stretch. of course, if i really wanted a stretch 2 xl as a practical cutting tool, i would get the standard frn version and not pay the extra for a g10 seki model, or wait until it's a salt, which is far more likely in my case.
gunmike1
Post by gunmike1 »
Are you able to measure the thickness behind the edge bevel for both knives? I should be getting my Cruwear Stretch on Monday but I’m curious how thin they are leaving the factory. I love thin slivers, and the Cruwear Stretch XL seems to fit the bill well.
PeanutButterFan
gunmike1 wrote:
Sat Dec 17, 2022 12:12 pm
The stretch 2 xl is plenty thin begind the edge. Definitely much thinner than the ayoob. They did a great job on the grinds
resonanzmacher
JD Spydo wrote:
Sat Dec 17, 2022 6:19 am
Between the two? I'd have the Ayoob. It's really got some special sauce and it's a better deal and at the end of the day I think it's just a bit better finished. And from the other thread and everything you've said about the Ayoob -- no, I can't see you liking the Stretch 2 XL in Cru-wear more than the Ayoob sprint either. I think we're both in Camp Ayoob for very similar reasons.
But I was surprised at how much I liked the Stretch 2 XL in Cru-wear. Maybe I shouldn't be, because Sal tends to design knives that fit me well from grip to usage. And I can see people coming from an EDC perspective opting for the gray Stretch. The only ding I have against it is if I really lean on the blade hard I can induce a tiny bit of lock rock. I do mean tiny. I'm picky about that in general but it's so miniscule that it doesn't really register for me in this case. Everything else, from handfeel to grip to blade geometry, is top notch.
Last edited by resonanzmacher on Sat Dec 17, 2022 6:45 pm, edited 1 time in total.
This is a great write up, thanks very much. Helps solidify my choice about the Stretch!
kennethsime wrote:
Sat Dec 17, 2022 4:53 pm
I hope you get one . Mine did not have bevel issues but needed a good strop razor sharp. Dan
ChrisinHove
Post by ChrisinHove »
Excellent piece! Thank you for sharing. Decisions, decisions…..
Pretty interesting comparison, I haven't looked into the XL yet and this gives me a good idea of size and ergonomics.
gunmike1
Post by gunmike1 »
I’m still considering the Ayoob. I’m very happy so far with the Stretch 2 XLso far. No lock rock, even grinds, centered, great QC. Just have a slightly uneven edge bevel on the clip side near the tip which will get fixed the first time I sharpen it. While I wish it was thinner at the edge I realize being around .018” at the edge on a 4” blade these days is quite thin (my Cruwear Delicas were .025”, which was highly disappointing). I’m the type that likes to run sub .010” edges on everything, but no production companies want to deal with warranty claims on 4” knives with ultra thin edges since people tend to do stupid things with their pocket knives.
Matus
Post by Matus »
Sat Dec 17, 2022 7:10 am
I am going to guess that it will not be long before the XL FRN comes out in k390. From utility point of view that would make the most sense to me, though I would be curios about the sturdiness of the whole knife. There are WORLDS between the bendy H1 Pacific and Ayoob. And while the Pacific is a nice knife, feeling the blade/spring move with ever cut that requires a little more power is not confidence inspiring.
ZrowsN1s
Post by ZrowsN1s »
I have both. If I could only keep one, I'd keep the stretch. This is going to be one of my top 10 favorites.
ZrowsN1s wrote:
Mon Dec 19, 2022 2:02 pm
I hear what you are saying, like both a lot and both are in my top ten too . I actually put both aside today to compare in pocket to my Police 3 . Dan
ZrowsN1s
Post by ZrowsN1s »
Mon Dec 19, 2022 2:10 pm
I think I'd prefer the Police4 G-10 to either. Would be all over a Grey G-10 Cruwear Police.
But between the Ayoob and SXL, the Ayoob is a superior SD tool, but for edc I prefer the thinner geometry, blade shape, and ergos of the Stretch.
Stretch xl vs pm2
Post by JD Spydo »
I'm completely dumbfounded that no one really spoke highly of the Sprint Run C-60 Cruwear Ayoob model on this thread comparing the two models ( Stretch & Ayoob). With the success of the Ayoob Sprint Run and so many people literally raving about it's release this past August I find it confusing that no one beside myself gave it a vote of confidence on this particular thread comparing it to the STRETCH model.
I have nothing against the Stretch model but given the success of the C-60 Sprint Run and all the fanfare on the C-60 thread I find that really baffling. This truly is a case of conflicting information and a really selective group of fans for both of these models as it seems to be. None like I've ever seen before.
Or do I need to see a "shrink" :thinking
