CPM 15v Manix 2
attila
Re: CPM 15v Manix 2
#1021
Post by attila »
IndianaTony wrote:
Tue Dec 20, 2022 1:53 am
Here’s something odd I just noticed…my knife is slightly magnetic. Just me, or a quirk of the manufacturing process?
Yours is not the only magnetic blade. I’ve noticed that several, if not most of my Golden Spydercos are slightly magnetic. I don’t know if any of my foreign-made ones are or are not.
Want: SPY27, K490, Swick 5
Ramonade
Re: CPM 15v Manix 2
#1022
Post by Ramonade »
My Chinese Efficient is too.
Mage7
Re: CPM 15v Manix 2
#1023
Post by Mage7 »
I wonder if some of the grinders are aligned North/South at the shop and pickup a magnetic field because of it.
Mine isn't magnetic. Got lot 7 - 22 A on the hidden tang stamp if anyone wants to compare
T.J.
Re: CPM 15v Manix 2
#1024
Post by T.J. »
Any advice on the best way to sharpen this with a Wicked Edge system?
ZrowsN1s
Re: CPM 15v Manix 2
#1025
Post by ZrowsN1s »
T.J. wrote:
Tue Dec 20, 2022 11:09 am
Patiently. Well, if you're going to reprofile anyways. For reference I just reprofiled a Maxamet Manix from 18 to 13dps. It took several days working for an hour or two each day. Probably 10hours total. Good lighting and a jewlers loupe can help confirm you are properly apexing.
It's tempting to press hard with the stones, don't. You'll wear them out.
I usually try to clamp near the handle on the flat part. And use the 'bug' as a reference for leveling (I clamp it so both bug legs are level with the clamp, makes it very repeatable). I have the point facing me, I think this reduces rounding of the tip in reprofiling (I have the point facing away for normal sharpening). Then I 'scrub' up and down one side for a bit, then the other side for a bit, trying to keep the bevels even. If the factory grind is lopsided (usually is) I focus on the side with the smaller bevel, as this will bring the apex more to the center and even out the bevels.
Once I've apexed on both sides and it is centered to my liking, I turn the WE around (I dont unclamp, I just rotate the base of the WE on my desk) then I sharpen with normal heel tip strokes through my grit progression. Then lightly strop to straighten everything out and remove any stray burr I missed.
T.J.
Re: CPM 15v Manix 2
#1026
Post by T.J. »
ZrowsN1s wrote:
Tue Dec 20, 2022 11:37 am
Thank you for your informative post. I find your technique regarding the tip very helpful. Any thoughts on what grit I should take 15V to? I'm looking for a balance between optimal "stickiness" and sharpness.
WilliamMunny
Re: CPM 15v Manix 2
#1027
Post by WilliamMunny »
T.J. wrote:
Tue Dec 20, 2022 12:15 pm
I am going to try to keep mine around 17dps for EDC. Going less I would worry about chipping (depending on your use case) going more I think you would lose some sharpness and edge retention.
But there is no correct angle it’s what works for you. Stick with the factory edge for a bit, if that DPS is lacking, they take the time to reprofile (if you have the equipment) to your needs.
Good luck.
ZrowsN1s
Re: CPM 15v Manix 2
#1028
Post by ZrowsN1s »
I like mirror polishes myself, but I've seen people with 400 grit edges that were sticky enough to grab hairs and with lots of aggression. Really a personal preference thing. 800 is a nice middle ground.
Rymanz
Re: CPM 15v Manix 2
#1029
Post by Rymanz »
There seems to be a reading comprehension issue in the alert thread. :rofl
:bug-red
Buddafucco
Re: CPM 15v Manix 2
#1030
Post by Buddafucco »
Rymanz wrote:
Tue Dec 20, 2022 1:09 pm
I tried changing the thread title. We'll see if that helps. :zipper
•• Beau
Re: CPM 15v Manix 2
#1031
it's almost as if people think a discussion forum is for discussions. i get it that people want the alerts, but it's really not that big of a deal.
and i say that as someone that's following the thread and keeps missing this knife.
Re: CPM 15v Manix 2
#1032
Bunch of people need to stfu over there! Honestly, not a single person cares how close they were to getting one. If you did, good for you! Talk about it here...not there.
If people want to continue to be disrespectful about the thread, especially those intentionally doing so...I'd just stop with the alerts all together if I were Beau. Let them fend for themselves at this point. He's trying to do everyone a favor!! I can't wrap my head around it.
Rymanz
Re: CPM 15v Manix 2
#1033
Post by Rymanz »
Tue Dec 20, 2022 1:18 pm
Well it bothers the rest of us who's adrenaline spikes every time they see the alert thread alert in their email inbox.
:bug-red
Re: CPM 15v Manix 2
#1034
Rymanz wrote:
Tue Dec 20, 2022 1:41 pm
honestly, i get it to a degree. i just don't think it's worth losing civility over.
salimoneus
Re: CPM 15v Manix 2
#1035
Post by salimoneus »
Senfkarte wrote:
Mon Dec 19, 2022 6:37 pm
The new, hot stuff of this knife is the steel.
I think the blade steel is pretty much the only selling point? There's a boatload of ball bearing lock Manix 2's already out there, even in this same exact bland color scheme. The stonewashing seems pretty mild and almost not noticeable. So the blade steel is the only practical difference.
Not saying it's not enough to garner interest, surely we can see it is enough, and I as well am curious to compare it to some of my current favorite steels. I can appreciate the work that has gone into it by all involved parties, and am interested in seeing the results first hand, since I already highly value other steels of similar composition.
But to me the difference from this steel to say the excellent 10V/K390 options we already have isn't worth it at secondary prices, especially since there doesn't even exist a 10V/K390 Manix 2 to be able to compare apples to apples. So hopefully I'll score one at the $158 or whatever, which I think is a good value price point. If not then I'll probably still manage to sleep at night just fine.
GeezyG
Re: CPM 15v Manix 2
#1036
Post by GeezyG »
Tue Dec 20, 2022 1:19 pm
👏Bravo. I feel like too much of a rookie here to say anything but damm. It's been repeated enuff that if it hasn't been understood by now I doubt it will. 🏃‍♂️⬅️ Me running to my phone to read someone's sad stories. Lol. But I digress. I think this drop is going as smooth as your "average "highly" anticipated spyderco sprint run". And much respect to the fellas that put in the work helping the rest of us. U can lead a horse to water but u can't pimp slap him if he talks instead of drinks.
Re: CPM 15v Manix 2
#1037
WilliamMunny
Re: CPM 15v Manix 2
#1038
GeezyG wrote:
Tue Dec 20, 2022 2:14 pm
I am guilty myself of making a non alert post in the alert thread. But it was a big thank you to the poster who just helped me find and get one.
Running the alert thread is awesome and a huge thank you to everyone contributing. It would be great if we did minimize the non useful talk in the thread, I am not sure how we can minimize it but realize no one is doing it in malice.
Good luck to everyone and don’t forget REC still has not dropped theirs. They said they would announce it on Facebook.
RamZar
Re: CPM 15v Manix 2
#1039
Post by RamZar »
You can store your Credit Card information securely on your iPhone and then “autofill” it when a website asks you for it.
Settings > Safari > GENERAL > AutoFill
- Credit Cards ON
- Saved Credit Cards
- Add Credit Cards
Also, more websites accept Apple Pay now.
Settings > Wallet & Apple Pay
- Add Card
vandelay
Re: CPM 15v Manix 2
#1040
Post by vandelay »
It looked like everything was going well for a few days. I figured it might stop getting derailed if people went in and saw a full page of alerts and OOS posts but somehow that made it worse lol.
