so call me stupid
- Irish Lager
so call me stupid
alright, so i am trying to remove the pocket clip off of my ss pro grip but the screws wont budge. Do they use locktite on them? if so how do i get them out. i dont like the clip, and as soon as i get it off i will begin to edc this knife. thanks for the help.
GS
GS
Say what you mean, Mean what you say! :spyder:
Avatar provided by Dialex
I had the same problem with one of my stainless ones. I ended up using a thin cut off disc to slot the heads of each screw for a straight head and then used a bigger screw driver to force them out. The phillips was just stripping on me.
Sears or Lowes has the cut off discs. Get the thinnest ones and a variable speed dremmel is best for control. Oh and wear safety glasses.
STR's Blog
STR's Blog
Yeah. Fun. Same problem here. :)
What I think is more fun is trying to hold a Delica sandwiched between 2 different screwdrivers at the same time to get the clip off of it. The fact that the slots are not that deep and are way too wide really help a lot too :D . They must expect me to get that clip off with a couple of nickels or some special tool that I don't have.
- Dr. Snubnose
- ghostrider
David,David Lowry wrote:Yeah. Fun. Same problem here. :)
What I think is more fun is trying to hold a Delica sandwiched between 2 different screwdrivers at the same time to get the clip off of it. The fact that the slots are not that deep and are way too wide really help a lot too :D . They must expect me to get that clip off with a couple of nickels or something or some special tool that I don't have.
Have you tried nickles, or even quarters. If you look at the slots on the nuts, you notice the slope inward, maybe even concave. I think they are made for coins, not screwdrivers. Old model 35mm SLR cameras were like that with thier battery compartments. I use nickles, and they seem to work much better than any screwdriver I tried. All this I am assuming your talking about the barrel bolt style clip. If so, give the coins a try, they should do a better job.
David
[INDENT]
Thread for tying tips:
Avatar provided by DAYWALKER
[INDENT]
- The Deacon
On "all metal" models, it often helps to heat each screw a bit with a soldering iron before trying to unscrew it to soften the locktite.
David,ghostrider wrote:David,
David
Yeah, what he said, nickels are perfect, almost obviously what was designed to be used on those screws.
"A flute with no holes is not a flute. A donut with no hole, is a danish."
Quietly lurking the Spyderco forum since 2003...
- Irish Lager
alright deacon, i will give it a shot. i dont have a soldering iron so i will have to ask my brother in law for his. but sounds like a plan.
doc, in the event that i cant get ahold of the iron, where can i get some corresionX?
thanks to all,
GS
thanks to all,
GS
Doesn't it seem odd that heat would be required to move the clip on an SS model?
What is a "non-knife nut" supposed to do? I mean that's OK for us folks but I seriously doubt that "they" would know that.
Also, thanks for the info about using a nickle. It doesn't seem that I can get it tight enough with nickles though that's why I use screwdrivers. If I use a nickle I can move the clip left to right and I figure it has more of a chance of trying to turn around and ruin the FRN.
That barrel nut/bolt is really not a good way to do things after having dealt with them on my Delica. I would rather just have the molded FRN clip now. :)
heres your link, lol
heres link for corosion x
http://www.johnfjensen.com/acatalog/cat ... orrosion-X
I havent tried it, but I do use the " Eezox" that he sells to lube my knives,
fwif I edc frn pro-grips, great blade
good luck
tom
good luck
tom
- Dr. Snubnose
