When was the last time you washed your smelly sharpmaker stones
James Y
Re: When was the last time you washed your smelly sharpmaker stones
Post by James Y »
yablanowitz wrote:
Sat Mar 26, 2022 8:25 pm
James Y wrote:
Sat Mar 26, 2022 5:52 pm
I use 0000 steel wool and Comet.
My Sharpmaker stones have never smelled any particular way, though. Not sure how they'd ever be smelly, unless you sharpen a knife blade with fish guts or food residue still on it.
Wouldn't steel wool add swarf instead of removing it? Scotchbrite pad and Barkeeper's Friend for me.
You're actually right. D'oh on me! I had been using the 0000 steel wool with mineral oil to remove some light rust from an old knife, and for some reason, the steel wool got crossed up in my mind. I also use Scotchbrite pads, but usually with Comet, to clean my SM rods. Glad that was corrected, lest someone actually thought my erroneous suggestion was a good idea...
Paraguy wrote:
Sat Mar 26, 2022 1:46 pm
If your answer is "i can't remember...", chances are you better go do it right now. I washed mine today and now their performance has increased twofold. It used to take me about 10 minutes to touch up a vg-10 kitchen knife and now it takes about 5!
I wash them quite often, increases performance a lot just like you said.
My tip: Cleanser for ceramic / ceran cooktops. Works amazing.
I use a product called "Ceraclen" (yes, spelled like that, so not "Ceraclean") - probably not available in thee US though, but certainly a ton of similar stuff.
Post by JD Spydo »
Sat Mar 26, 2022 5:50 pm
LakeOconee wrote:
Sat Mar 26, 2022 5:45 pm
What kind of eraser is best?
Vinyl block from the craft store?
generic mr clean erasers + bar keepers friend gets them looking new.
I'm probably a little more prompt that most people when it comes to cleaning the stones. Because after I get just two or no more than 3 good sharpenings I immediately clean the stones with "Bar Keeper's Friend" cleanser and give them a good and thorough scrubbing. And by doing it frequently like that I find the "bite" on my stones is a lot more consistent.
I've only used the Mr. Clean Erasers one time and I find that a good scrubbing with Bar Keeper's Friend cleanser sure keeps the stone performing better. The only drawback to those ceramic stones is that they clog up quicker than most any other type of stone I use. But it doesn't take very long if you do it frequently.
Half Sack
Location: Alberta, undisclosed location of the Weapon Plus Program
Post by Half Sack »
Oops, better get cleaning now.
DrHE
Post by DrHE »
I use all my Spyderco stones a lot and clean them with BKF and a green scrubby pad weekly. I call it washing my sharpening dishes. If you can see steel build up give them a quick scrub and they work better. The Ultrafine you will end up cleaning each use at minimum as it loads up fast.
M.N.O.S.D. 0031
Ramonade
Post by Ramonade »
When we mention erasers, it seems that not everyone is speaking of the same ones !
I personnally use an eraser meant for graphite, for drawing. Works really well and when it's not enough anymore (it manages to get something like 95% of the steel out), it's time for BKF.
Superflex
Post by Superflex »
Yep, the white pencil erasers are so much easier for cleaning the rods. No need to get out the BKF and an abrasive pad.
Pentel set of three will last you a looong time
Hardbawl
Post by Hardbawl »
You know, ever since I learned that I got a sharper edge from using extremely light pressure on the Sharp Maker stones they don’t really load up fast. So, I haven’t cleaned them for way too long. Will correct that today. Thanks for the heads up.
Holland
Post by Holland »
I've cleaned mine less than 5 times in the last 10 years.
Might be time to just buy some new rods
Kevinim82
Post by Kevinim82 »
I use the white vinyl ones.
Was never a space cadet, but with LC200N I might be more in space than a cadet.
MNOSD 0009
Ramonade
Post by Ramonade »
Hardbawl wrote:
Sun Mar 27, 2022 11:15 am
For sure ^^ I almost end up using not enough pressure on stones most of the time. I lift most of the knife weight, so there's really little to no pressure. Maybe I should start adding more.
The Sharpmaker is a particular case though, I won't change anything on it since the contact surface is ridiculously small !
Paraguy
#32
Post by Paraguy »
Half Sack wrote:
Sun Mar 27, 2022 7:28 am
How badly do they smell?
"Some call me...Tim?"
Paraguy
#33
Post by Paraguy »
Holland wrote:
Sun Mar 27, 2022 11:55 am
I wanna see a picture...
Tristan_david2001
#34
Post by Tristan_david2001 »
Using the spyderco tri angle sharpener I give the stones a wipe with some abrasive paper towels after every time I’m finished sharpening a blade. I noticed a few months ago that if steel dust just sits on there and builds up it’ll makes them too slippery, and not sharpen up your blades as good.
:bug-red-white:
LakeOconee
#35
Post by LakeOconee »
^What are "abrasive paper towels", are they the blue ones from auto parts stores?
TIA
:bug-red-white MNOSD Member #0037
Tristan_david2001
#36
LakeOconee wrote:
Sun Mar 27, 2022 5:29 pm
TIA
Yeah the blue heavy duty Scott ones are what I typically use because of their texture
:bug-red-white:
yablanowitz
#37
Post by yablanowitz »
Bar Keeper's Friend and a Scotchbrite pad, ten minutes scrubbing and you'll think you did buy new rods.
cabfrank
#38
Post by cabfrank »
I agree. They load quickly, but they clean quickly also, really in just a few minutes. I haven't tried erasers, but Scotchbrite and whatever abrasive cleaner you have will do the trick.
Filoso-
#39
Post by Filoso- »
I usually use a pencil eraser… fast and clean…
Half Sack
#40
Post by Half Sack »
Paraguy wrote:
Sun Mar 27, 2022 4:27 pm
Smells like my last sharpening session wasn't as effective as I thought
