What is your oldest (earliest) Spyderco ?
Re: What is your oldest (earliest) Spyderco ?
early '90s ladybug was my first knife. i was so happy to find it again after years of not knowing if i still had it.
Wandering_About
This stainless handle Delica 4 from around 2006-2008 (I think).
MNOSD member #0035
MNOSD member #0035
yablanowitz
The G-2 steel stamp was used from around 1991 to 1993 and was replaced by the GIN-1 stamp around 1994. At least, that's what Spydiewiki says.RevMike wrote: ↑Sun Mar 13, 2022 4:40 pmThere are a couple that might be older or at least close but I don't know for sure.
Anybody know how to date the molded clip Endura or Rescue? I think both could be late 80s but also early 90s.
There are a couple Workers that could be in the running but I'm not sure. One is Zowada Damascus but not from the evolution set. I still think that would place it around 90-91.
The strongest contender to the Economy is a Worker stamped Gin1 which was mid to later 80s if I remember correctly. I feel like the no steel designation was first, then G2, and then Gin1.
If anyone has any insight into dating the 4 knifes mentioned above I'd love to hear it.
Like Sal said, the lightweights didn't come out until the early 90s. If you can post pictures of the clip fron the top and side so he can see the width and thickness, Sal might be able to at least tell you which mold change it is.
It's the ATS-55 Endura from the late 90s for me.
I got these Delica’s back in ‘93 or ‘94 along with a single angle Sharpmaker. Both are G2 steel.
The PE Delica lost its clip after snagging it on the bedroom doorway striker plate too many times. I saved the knife and after moving to Colorado years later I had Spyderco replace the stub with a metal clip.
Thank you.yablanowitz wrote: ↑Sun Mar 13, 2022 7:06 pmThe G-2 steel stamp was used from around 1991 to 1993 and was replaced by the GIN-1 stamp around 1994. At least, that's what Spydiewiki says.
If those 4 are all early to mid 90s that means the Economy is definitely the oldest by far. I'll have to look around a bit more but I think that's the only one I have from the 80s.
374
s in 85 steel flavors.
- Manixguy@1994
My Merlin is older but cherish the C44 the most . MG2MNOSD 0002 / Do more than is required of you . Patton
This is my first Spyderco. It was in my pocket in high school 1988.
This is my oldest I acquired a few years ago. About 1983.
Thank You - It was great seeing some of the earlier Spydercos !
And Sal - No Number on my Terzoula in the picture, but if I remember correctly, this particular Terzuola was returned to Spyderco because the liner lock was not functioning correctly, and Spyderco had to replace the blade in order to get the liner lock to function properly. I was told at the time it was the last Terzuola blade that they had in the parts inventory.
Where were the serial numbers located on the early C-15 Terzuola's ?
I will have to find my 2nd C-15 Terzuola to see if it is serialized ... it is in one of my bug-out bags in one of my vehicles, I have Spydercos everywhere !
All the best,
NASA50
All the best,
NASA50
Hi NASA, the serial number is located on the presentation side of the blade, just in front of (toward the tip) the Spydiehole. The Terzuola was the 2nd or 3rd Spydie I purchased. Maybe the 4th. The C01S Worker was the 1st.NASA50 wrote: ↑Mon Mar 14, 2022 6:03 pmThank You - It was great seeing some of the earlier Spydercos !
All the best,
NASA50
Mariner SE, maybe 1989
- Archimedes
I have several 2 screw Military's. I am guessing they are the oldest in my collection.
Mine is an AUS-8 Serrated Delica w/ molded clip. Bought 25 years ago from REI. Used to carry it rock climbing.
These are my oldest Spydercos. I bought these two (Delica and Endura) at the same time at the Valley Indoor Swapmeet in So Cal. I believe the year was 1991.
I'm proud to say both molded clips are still in tact.
@ckc_knifemaker on Instagram.
Hi Xplorer,
Very nice examples of the first generation FRN Clipits. I designed them on an airplane flying from Hawaii to Denver. The "humps" at the pivot was to provide purchase for your index finger to learn how to open the knife with one hand.
- Larry_Mott
Here's my oldies...t :)
Accutronman
The extremely rare and one of the few existing Bob Terzuola C15PL (left handed version)
I purchased my first Spyderco while I was visiting Germany in August 2000. It’s a Japanese-made Native II all-stainless steel with an AUS-10 CombinationEdge blade. Still works great. Thin but a bit on the heavier side due to it being all-stainless steel.
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
- Larry_Mott
I have one too, albeit a right handed one. Yours look very minty!Accutronman wrote: ↑Tue Mar 15, 2022 6:12 amThe extremely rare and one of the few existing Bob Terzuola C15PL (left handed version)
CCBE9A8D-15A2-4F70-844F-F947F6F309D7.jpeg8DDAF38C-56D4-4D04-B525-5C688B3B1B11.jpegA5BADA68-2F43-4075-A43A-A160FED20941.jpeg96B46C9D-44A5-4C62-817A-1AF8B8BC0682.jpeg
