How'd you wrap your mule handles with paracord? (pics welcome)
AlexRus
Re: How'd you wrap your mule handles with paracord? (pics welcome)
Post by AlexRus »
My Z-Wear Mule paracord-dressed
Araignee
Post by Araignee »
I had always wondered how the paracord wrappings were done, excellent thread :cheap-sunglasses
Thanks yablanowitz for the picture heavy tutorial 👌
Ramonade
Post by Ramonade »
AlexRus wrote:
Sun Jan 23, 2022 10:55 am
Pretty nice, that's dense ! does it have some girth width ?
AlexRus
Post by AlexRus »
Ramonade wrote:
Mon Jan 24, 2022 2:53 pm
Yup, a little bit
Ramonade
Post by Ramonade »
AlexRus wrote:
Mon Jan 24, 2022 2:58 pm
Yup, a little bit
Nice ! Seems comfortable. I might not do a ton of paracord wrapping in the future since I've equipped myself to do better scales than i did free hand, but it makes me want to try such a configuration.
yablanowitz
Post by yablanowitz »
I'm glad you found it helpful. I've tried a bunch of different wraps, before and since, but this one gave me the best results for my use.
Ramonade
Post by Ramonade »
I have to say, I did some work on wood, in the kitchen and with cardboard already : The width this wrap gives is really nice for cuts that require some force.
yablanowitz
I've done a lot of hard cutting with Mules wrapped this way. Gives me plenty of traction, just enough padding and doesn't add too much bulk to bother me when I carry it across the small of my back. Careful, though. If you like it too much, you may never get around to finishing scales.
Ramonade
Post by Ramonade »
That's an issue I thought about only after a few days... might be too late!
hereiamu1
Post by hereiamu1 »
cholla_remover
Post by cholla_remover »
Nice thick wrap there. Looks twice as wide as other pics here, yet it doesn't appear that you double-wrapped it?
hereiamu1
#32
Post by hereiamu1 »
no double wrap, maybe the others have fewer cords inside?
cholla_remover
#33
hereiamu1 wrote:
Sat Jan 29, 2022 8:37 pm
It looks good! I might try this with additional wraps of cord between the holes in the tang (as in your first photo) to see how girthy I can get it.
Ramonade
#34
Post by Ramonade »
I do not know what you meant by fewer cords ? This wrap was pretty hard cause I had to cut the end of the cords inside to make them go through the 3/16 hole. Otherwise it would never have gone through !
archangel
#35
Post by archangel »
If you feel you need more material, try double wrapping. You might remove the core on the first/inner layer, then use the standard PC for the outer layer. It works perfect for me. Just give it a go, you can always reverse it. You just need to use different holes for the start....
Michael
ZrowsN1s
#36
Post by ZrowsN1s »
A simple handle wrap and cardboard ducttape sheath.
AlexRus
#37
Post by AlexRus »
ZrowsN1s wrote:
Sun Feb 20, 2022 5:48 pm
Well done! 👍
ZrowsN1s
#38
Post by ZrowsN1s »
AlexRus wrote:
Wed Feb 23, 2022 12:36 am
Well done! 👍
Thanks!
Ramonade
#39
Post by Ramonade »
Nice ! And the blue them is a nice touch (that sticker is a killer one)!
ykspydiefan
#40
Post by ykspydiefan »
yablanowitz wrote:
Fri Apr 28, 2017 11:31 am
http://www.bladeforums.com/threads/cord ... le.931472/
Link to a How To that I put together and posted on Blade forums a while back. It's how I've done all of mine. I think you may need to be logged in there to get the link to work.
This cord wrap tutorial is important to keep in mind. Cord wrap is the cheap and important way to get your Mule into service.
This tutorial changed my mind and really helped to keep a cord wrap tight until I wanted to take it off. It also opened a door for me to spend more money on more Mules and not spend on tooling for good/fancy/or more permanent scales.
