Native 5 G-10 with Liner Options
I have a friend that is looking for a Native 5 G-10 that has liners. What models/steels have the liners? This has nothing to do with strength and has to do with the scales that he is getting that requires liners. So what are his options?
Is the newer standard production Native 5s in S30v have liners or linerless?
Thanks!
Native 5 G10 with Liners:
- S35v
- Older model S110v
Thanks!
- S35v
- Older model S110v
- VooDooChild
Re: Native 5 G-10 with Liner Options
I think they are all linerless now. Im pretty sure the s110v still had liners up until about 3 years ago... not quite sure.
Your going to have to find an older one.
Ok good to know. So older model S110v added to the options. Thanks.VooDooChild wrote: ↑Fri Oct 22, 2021 4:16 pmI think they are all linerless now. Im pretty sure the s110v still had liners up until about 3 years ago... not quite sure.
Tell your friend if he is searching through ebay or bladeforums, look at listings with real pictures instead of stock images and the native 5 g10 models that have a screw in place of a lockbar pin will have liners.
- RadioactiveSpyder
Hi there, there are a few sets of N5s with liners: the older S35VN ones, the S110V ones in blurple G10 and in peel-ply CF, and the clad 154CM/S90V one in CF. I have an older set of custom N5 scales and I will warn you that the handle dimensions on the blurple G10 S110V variant in particular is a bit “off” compared to the others, making scale swaps with that one basically undoable. I’d stick with finding only the older S35VN ones with the screwed-in stop pin as mentioned, or either of the non-fluted CF ones if they want S90V. Cheers, Radioactive
More good info. Appreciate it.RadioactiveSpyder wrote: ↑Fri Oct 22, 2021 8:53 pmHi there, there are a few sets of N5s with liners: the older S35VN ones, the S110V ones in blurple G10 and in peel-ply CF, and the clad 154CM/S90V one in CF. I have an older set of custom N5 scales and I will warn you that the handle dimensions on the blurple G10 S110V variant in particular is a bit “off” compared to the others, making scale swaps with that one basically undoable. I’d stick with finding only the older S35VN ones with the screwed-in stop pin as mentioned, or either of the non-fluted CF ones if they want S90V. Cheers, Radioactive
Vladimir1970
Hello dear community! In order not to spawn topics, I want to ask in this thread (I hope the topicstarter does not mind). Is the Native 5 FRN blade interchangeable with the Native 5 C41GP5 ?
Michael Janich
Dear Vladimir1970:
Stay safe,
Mike
Stay safe,
Mike
- araneae
Seems like you can swap them, but you'll want to swap the lock bar with it.Vladimir1970 wrote: ↑Tue Nov 09, 2021 6:18 amHello dear community! In order not to spawn topics, I want to ask in this thread (I hope the topicstarter does not mind). Is the Native 5 FRN blade interchangeable with the Native 5 C41GP5 ?
-Nick
Last in: N5 Magnacut
-Nick
Vladimir1970
That is, you will have to change along with the Back Loсk ?
- steelcity16
They need to pump out a Cru-carta Native soon since they already have the linered version from the pre-CQI models. Should be as simple as slapped some Micarta slabs on it! I'd take a DLT Trading exclusive Cru-ple Native with the liners as well. It really was such a sweet tank of a knife with those liners. Just never had the "tough" steel like Cruwear to match. The liners on the Cru-carta PM2 made me like that model again after being PM2-less for a long time.
Vladimir1970
- araneae
I'm sure the wish list is long, we just need to be patient as they deal with the same production issues that the rest of the world is dealing with.
-Nick
-Nick
