Best edge bevel for sharpening
- AllenETreat
Time for an "info thread"...
Which edge bevel do you use when sharpening your :spyder: ?
I use about a 40 degree ange on my Cricket ( seems to work ) and
a Gatco Tri Seps diamond hone ( one of these days I gotta get a
204 sharpener! )
What say the augurers?
AET :D
204 sharpener! )
AET :D
All men dream, but not equally. Those who dream by night, in the dusty recesses of their minds, awake in the day to find that it was vanity. But the dreamers of the day are dangerous men, for they may act their dreams with open eyes to make it reality.
T.E. Lawrence
T.E. Lawrence
- ghostrider
I usually use 30 for my :spyder: 's. Other knives don't really need it since I started carryng :spyder: .
[INDENT]
Thread for tying tips:
Avatar provided by DAYWALKER
[INDENT]
- Michael Cook
use those brass rods, people!
:spyder: softer kitchen type or older era stainless steel is a bit too soft to hold a 30 degree bevel but the vg-10 and cpms30v sure can! snicker-snack! :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
Senate wrote:the 40 of the sharpmaker is working great for me...
Aloha Allen!
Same as Senate...but like I have mentioned, I usually been freehanding so i don't really know! :p :o
God bless you buddy! :cool:
Proverbs 16:3...Commit YOUR works to the LORD, and YOUR plans WILL succeed!
"Where's the best little big knife not designed by Sal or Eric?" ~ thombrogan, WSM
Avatar by my KnifeBrother, DiAlex...C102 Adventura designer, 2005 Spyderco Forum Knife!
30 for Spyders / BM & 40 for others
Yeah -- what Gerard, Michael & Mariner said.
"All your :spyder: are belong to us."
** WTC # 1032 1533 **
I freehand sharpen my Cricket and Delica. Both have different degrees. I haven't measured them but they cut like razor blades and hold their edge well. I use a crock stick mostly followed with a leather strop with jeweler's rouge on it sometimes. I do the sharpening mostly by "feel" as the eyesight isn't what it used to be. I haven't needed any agressive stones even tho I have them. I just take my time and use patience. It's worth the minimal effort to have them sharp. :)
If I'm using a Sharpmaker, I almost always do the initial sharpening at 30 degrees. On some fixed blade knives that will be used hard hard, I take the 30 degrees to the edge but don't raise a burr, but switch to 40 degrees to do that ... in other words, 30 degrees w/ a 40-degree edge is the most obtuse I'll go, only for fixed blades.
My feeling has always been: if my folder can't handle 30 degrees, I'd rather get a better knife, than go to 40 degrees. I'm exaggerating a little bit, because I often take a few swipes at 40 degrees to remove the burr, or even more swipes on knives I know will be used hard. But there's almost never a reason to go to a straight 40 degrees on a quality folder with good quality steel and heat treat -- you're giving up a ton of performance for nothing, you may as well have gotten a knife with junk steel if you're going to put an obtuse edge on. The whole reason to buy a premium steel knife is for premium performance, not to get obtuse-edge performance at three times the cost.
The exception, of course, is if you know that you're using your knife hard enough that it will chip out or indent badly otherwise. Michael brought up soft steel kitchen knives, which are an example of lower-quality steel that won't always hold up to 30 degrees without indenting and turning badly.
Joe
Joe
