Para 3 and Para 3LW Blade swap?
MrMatnenko
Post by MrMatnenko »
Have a good day, everyone! Just out of curiosity, if Para3 and Para3 LW blades swappable? Currently have P3 Sprint Forest Green. Wondering if swap DLC blade from LW version?
Matus
Re: Para 3 and Para 3LW Blade swap?
Post by Matus »
Well - Nick Shabazz did swap blades between LW and G10 version and had no issues. I was considering it too (would love to get Maxamet in blue LW handle). Just try it - the blade do have the same shape, the only question is whether the DLC coating is going to make a difference.
Henry_P
Post by Henry_P »
I have personally tried this between an M390 Para 3 and a REX 45 Para 3 LW and it worked fine. I did it mostly because I was curious, but it’s important to note that both of my blades were satin finish. I have no idea how the DLC coating will affect this swap.
Para 3 Maxamet | Para 3 CruWear DLC | Smock M4 Jade G-10 | Shaman Z-Wear Micarta | Salt 2 LC200N Wharnie | Chaparral Birdseye Maple | Lil’ Native S90V CF | Dragonfly 2 20CV | Ladybug K390 | CRK Small Sebenza 31 S45VN PJ
MrMatnenko
Henry_P wrote:
Fri May 21, 2021 9:34 am
appreciate your experience! thus it will work with DLC
FRNFanboy
Post by FRNFanboy »
I’ve done this with a spy27 lw and an s30v para 3 and had no problems.
MrMatnenko
FRNFanboy wrote:
Fri May 21, 2021 12:05 pm
thank you! Did you place Spy27 on you P3?
darkjabroni
Post by darkjabroni »
I tried to take the 20cv blade from the recent knifejoy LW exclusive and put it into the m390 g10 para 3 from DLT and the fit was too tight.
I could fully seat the blade and open and close it but there was too much resistance, and it almost felt like it would have a half stop before more resistance in either closing or opening.
These two knives were pretty far apart in terms of production though, so ymmv? Try to keep the models relatively close in terms of production date I guess.
JMM
Post by JMM »
FWIW I have swapped DLC & Satin in both directions (Para3 <-> Para3 LW) without any issues from more than a half dozen different models and have yet to come across a problem.
MrMatnenko
JMM wrote:
Sun May 23, 2021 6:13 am
thank you! good news!
foofie
Post by foofie »
I have personally swapped into the LW frame: maxamet, s110v, rex45, m390. The latter two were in the days before the LW versions came out. They all worked fine both ways.
MrMatnenko
foofie wrote:
Sun May 23, 2021 5:18 pm
got it! appreciate!
FRNFanboy
Post by FRNFanboy »
MrMatnenko wrote:
Sat May 22, 2021 6:53 am
Yes! Added micarta scales too, great little knife.
MrMatnenko
FRNFanboy wrote:
Wed May 26, 2021 7:48 am
Thank you!
