IT'S KNIFE GIVEAWAY TIME!!
JRinFL
Re: IT'S KNIFE GIVEAWAY TIME!!
#121
Post by JRinFL »
The lighting was poor, and for some reason I failed to upload the edited picture.
Netherend
#122
Post by Netherend »
The red scales are pleasant
Just one more knife...
JRinFL
#123
Post by JRinFL »
David included his own Product Information Guide in the box. It's a hoot to read & has some useful sharpening/maintenance information. Maybe we can get David to post a copy here?
nerdlock
#124
Post by nerdlock »
Congrats JRinFL and way to go, Dave! I commented late so that I won't be included in the draw LOL.
JRinFL
#125
Post by JRinFL »
Mon May 03, 2021 3:47 pm
JRinFL wrote:
Mon May 03, 2021 3:45 pm
It’s here!
Considering all it went through, it looks practically new. Outside of the color and Evil D’s edge, that is.
I have to thank David again for his very generous give away. It must have been a sacrifice to give up such a good knife!
Very cool!! :)
Though: It does not look really red anymore - ?! (Just the lighting in the pic I guess)
Here is a much better picture showing the true colors.
#126
JRinFL wrote:
Tue May 04, 2021 7:22 am
LOL, I had to pull it out of the recycle bin but here ya go.
Congratuations! You are now the proud new owner of this wonderful Caribbean! Enclosed are some basic care and feeding instructions which will ensure that you and your new friend live a long and (mostly) healthy life!
1. Your new friend enjoys being sharpened at 30 degrees inclusive/15 degrees per side. The front serrations have been reprofiled down to well below 15 degrees at the top of the bevel, but the very edge/micro bevel is best kept at 15 degrees for edge stability. The back side of the blade may also be sharpened at 15 degrees, but you may also enjoy leaning the blade over towards the Sharpmaker rod until the blade is nearly flat against it. This will achieve an even lower inclusive edge angle and increase cutting performance.
2. Your new friend comes pre lubed with Phil Wood bearing grease. This is our preferred pivot lube and we find that it helps to keep pocket lint and crud from making its way into the pivot area. Should you decide you want to try some other type of lube (no idea why you would), it is advised that you disassemble the knife and clean this grease off before adding your own (surely inferior) lube.
3. Your new friend enjoys a healthy diet of various materials which include but are not limited to; Drywall, old car tires, electrical wires, coax cable, cow bones, aluminum cans, hard and soft woods, fingers, and the occasional squirrel who can't outrun you. We at Evil D Inc. encurage you to experiment with feeding your new friend a healthy variety of foods! We're sure you'll discover all sorts of new favorites.
4. Should you and your new friend experience edge damage due to explosive gastral intestinal catastrophie or other similar mishaps, it is advised that you fix this edge damage using the Sharpmaker CBN or Diamond rods. This can be achieved simply by sharpening the knife as you would with any other grit, being sure to use a very gentle touch and avoiding too much pressure, while making passes until you see the edge damage is removed. It is recommended that you stick with the 15 degree setting to accomplish this, and then continue moving on through the grit progression using the medium/fine/ultra fine rods. This will quickly correct whatever poor choices you have made and bring the edge back to fighting shape.
We at Evil D Inc. are more than delighted to bring you this exciting new experience and are sure that no (permanent) ill effects will come to you as a result of inheriting this Caribbean and want to wish you many years of exciting new adventures!!
DISCLAIMER: Under no circumstances is Evil D Inc. (LLC) responsible for your lack of interest and utter disgust in other knife models as a a direct result of receiving this knife. Furthermore, Evil D Inc. will not, under any circumstances, be held responsible for your loss of interest, desire, appreciation, sex drive, mental focus, or any other form of lust towards other knives. Evil D Inc. reserves the right to deny all involvement in this situation, should you choose to sell off all of your other knives after experiencing the sheer brutal awesomeness that is the Caribbean. Additionally, Evil D Inc. shall not be held accountable in the event of bodily/property/intellectual harm of any kind due to the poor handling of this instrument of mass separation.
JRinFL
#127
Post by JRinFL »
That PW bearing grease must be the best. This is the smoothest knife!
#128
Haha, just gets better and better. Got me googling that grease now (though I admittedly have never had any issues using BM Blue Lube myself)
#129
JRinFL wrote:
Tue May 04, 2021 12:57 pm
It's my favorite lube but I did also polish the blade tang and that's a big part of the smoothness. Even if you just polish the detent ball path it helps a lot.
cabfrank
#130
Post by cabfrank »
D, that product info guide is priceless!
JRinFL
#131
Post by JRinFL »
Evil D wrote:
Tue May 04, 2021 1:36 pm
It is impressive! If we could get Spyderco to do a quick machine polish on the tangs, it would increase their appeal.
rashman
#132
Post by rashman »
very nice work Evil D! congrats again JRinFL - i’m excited to know how your new friends diet exploration works out
may the 4th be with you
