Which two would you choose?
I’m going to be trying to get two mules so that I can do a comparison in the spirit of the mule team. I am curious about the 28 and 29, but 31 is also intriguing. If you were choosing two from these three that are coming ‘soon’, which two would you choose?
Re: Which two would you choose?
Hi Wisby,
Welcome to our forum.
Personally I'd go with Z Max (I'm super excited to try a Maxamet competitor in a mule) for long term edge holding, and Spy 27 because it's Spyderco's proprietary steel.
As a maker, I'm interested in s45vn, but for a user I'm not sure the difference from s30v or s35vn will be that noticeable.
I think Spy 27 and Z Max will get you the widest range to use, play with, enjoy, test, etc.
As far as I know - S45VN and SPY27 are fairly similar. Both stainless steels with decent edge retention. SPY27 is a little tougher, S45VN is a little more corrosion resistant. If that info is outdated/incorrect, I'm hoping someone will correct me.
Z-Max is going to be notably different. Prone to corrosion but crazy edge retention (again far as I know.) Everyone is going to want a Z-max, so might be harder to get, but Z-Max and one of the other two would be what I recommend if you're looking for noticeably different properties.
- elmeringalo
- Tucson Tom
If it has to be two, Zmax and Spy27.
- Naperville
Z Max and S45VN
Thanks all!
I was interested in Z-MAX and SPY27 the most and your comments have solidified that - as well as the fact that SPY27 will become available first. So I will be trying to get a MT28 when they become available and if they are not available by the time I am ordering then I will just have to go for the S45VN instead of SPY27. But like all of you, I am definitely going to try for the Z-MAX.
- WilliamMunny
How do you know there will be a order to their release? I thought they might all go at the same time.wisby wrote: ↑Mon Feb 08, 2021 9:53 amThanks all!
WilliamMunny wrote: ↑Mon Feb 08, 2021 4:37 pmI see in the sticky first thread of this Mule forum that the 28 SPY27 has a release date defined later this week but I don’t see release dates for the other two yet.
