K390 Delica HRC?
Londinium Armoury
K390 Delica HRC?
Post by Londinium Armoury »
Hi Sal and everyone, was just wondering what the HRC is running at on the new K390 line from Seki factory. I got a new Delica in K390 and me and a few people were trying to find out what the actual numbers were if you don't mind sharing specifics. I tried looking around but haven't found anything.
Cheers.
It's better to be a warrior in a garden, then a gardener in a war
Accutron
Re: K390 Delica HRC?
Post by Accutron »
The only Seki K390 I know of that's been tested so far is the Police 4. Three different examples tested at 64.2, 65.2 and 65.5.
https://docs.google.com/spreadsheets/d/ ... 0iEWrdJGU/
Londinium Armoury
Accutron wrote:
Sat Nov 14, 2020 5:07 pm
I wonder if the new ones are the same, same factory so it might be similar levels, I was guessing it was high, mine is still shaving hairs 3 weeks in.
Cheers.
Buddafucco
Post by Buddafucco »
(Re: HRC Database
Postby EngDevGr3 » Tue Sep 01, 2020 8:06 pm
I just got a Delica k390. The results were a bit surprising. It was poked twice, with the results of 66.4 and 66.5 HRC)
I found this in the HRC Database thread.
•• Beau
The Mastiff
Post by The Mastiff »
I recall the days when everything was run at rc 58-59. Even when new steels were used they were not heat treated to bring out their best performance. Heck if they are rc 62 or above I'm more than happy.
Joe
Londinium Armoury
Buddafucco wrote:
Sat Nov 14, 2020 5:51 pm
(Re: HRC Database
Thanks you, that's the info I was looking for. it seems like a test from the newest recent batch as well, from the same batch I have, nice.
nerdlock
Post by nerdlock »
(Re: HRC Database
Wow, that's good!
I just hope the upcoming P4 LW K390 will also be heat treated the same...couldn't find a good P4 G-10 nowadays.
Bemo
Post by Bemo »
Can't wait for my Endela! I think this is one of the best new steels in awhile.
Hi Londinium Armoury,
We always try for optimal working hardness for the steel we're using..
Buddafucco
nerdlock wrote:
Sat Nov 14, 2020 8:43 pm
(Re: HRC Database
Wow, that's good!
Yeah, i missed out on the P4 g10 k390. I haven't had any luck finding a nice used one either.
•• Beau
Accutron
Post by Accutron »
(Re: HRC Database
Wow, that's good!
This seems overhardened, particularly with the Delica's thin blade stock. Bohler's maximum recommended hardness is 64 HRC. K390's toughness isn't fantastic anyway, and at 66.5 HRC, it's getting down near Maxamet.
GarageBoy
Post by GarageBoy »
After the abuse Shawn has put his k390 police through, it looks plenty durable to me
The Meat man
Post by The Meat man »
Accutron wrote:
Sat Nov 14, 2020 10:22 pm
(Re: HRC Database
Wow, that's good!
Steel foundry HT recommendations are generally for applications other than knives.
I'm stoked to hear that it's being run as hard as it is. I run my K390 Police at around 9~10 dps and it's tough enough for EDC even at that extreme angle.
- Connor
Baron Mind
Post by Baron Mind »
The Meat man wrote:
Sun Nov 15, 2020 2:13 pm
(Re: HRC Database
Wow, that's good!
Precisely. Additionally, a steels working hardness can change based on a particular heat treat. So the foundries general recommendations, nor their recommended heat treat is tailored for cutlery.
GarageBoy
Post by GarageBoy »
Is the delica 4 "slicy-er" than the endura 4/police 4?
The Meat man
GarageBoy wrote:
Sun Nov 15, 2020 5:54 pm
The Delica has slightly thinner blade stock, so possibly a little, but the primary grind is probably the same.
- Connor
Baron Mind
I'd say yes. The Delica has thinner stock, and while the Delica isn't as thin behind the edge as one might expect, most P4s I've seen/heard about came a little thicker bte than the typical 20 thousandths on inch you usually see. I ended up thinning/convexing my edge a little by hand, and it cuts great now.
nerdlock
Post by nerdlock »
(Re: HRC Database
Wow, that's good!
Seems pretty tough to me.
https://youtu.be/TI53ziibeiQ
nerdlock
Post by nerdlock »
GarageBoy wrote:
Sun Nov 15, 2020 1:29 pm
Precisely why despite my aversion to large knives, I'm on the lookout for the P4 G10 K390...or if that isn't possible, consider purchasing the P4 LW K390.
lorgar
Post by lorgar »
I hope I could buy a P4 in K390 here in Europe at dealers shop, but not sure I will be lucky to see one enough earlier.
