DSH007
#20981
Post by DSH007 »
Rick H.
ThomC
#20982
Post by ThomC »
Wed May 27, 2020 10:34 am
ThomC wrote:
Wed May 27, 2020 8:29 am
Fresh off the newly arrived Sharpmaker. Vivi's technique works wonders, every serration now shaves effortlessly.
Looking at the edge it looks like that at first you tried the 15 degree setting, but did not hit the apex (but higher up on the blade) and had to use the 20 degree then? Or are you in the process of thinning out or even reprofiling?
Just asking, cause while my particular Pac Salt SE came with an angle of closer to 20 degrees, while many said theirs came with more or less 15... wonder how this is on the PM2...EDIT: Meant to say Para 3 of course
That's a Paramiltary 1 ! I went straight to the 15 degree setting, and tried to sharpen the knife by bringing the bevel to the 'clicking' point on the stone, like Vivi mentions in his video.
I figured that since my former PM2 was at 30 degree and my Millie is at 30 degree, I'd go with that.
European amateur knife enthusiast
Hikes and outdoors galore
🏍️Motorcycle enthusiast
In the knoife box : M4 Millie, Spyderco Perrin Street Bowie, TOPS Tanimboca
In the future : CE/SE/Rex45/MagnaCut Millie, K2, Slysz Bowie, linerlock Sage
ThomC
#20983
Post by ThomC »
DSH007 wrote:
Wed May 27, 2020 11:26 am
Purrdy. The wave gives it a very nice angle play.
GiftedMisfit
#20984
Post by GiftedMisfit »
:cussing
#20985
ThomC wrote:
Wed May 27, 2020 11:28 am
Right! Looked like the Para 3 on my phone screen (mainly due to the just 5 scallops of the serrations)
/ Ok, so you set up the SM at 15 degrees, but then did somehow "freehand sharpening", since you tilted the blade till the angle was right? (And did not strictly go perpendicular to the ground up and down)?
Was just asking in my precious post, cause there is a line on your knife where the black coating is removed just where the apex ends towards the primary bevel. That´s typically the case when one tries to sharpen a lets say 40 incl. (PE in that case) apex on the 30 incl SM setting.
ThomC
#20986
Post by ThomC »
Wed May 27, 2020 11:42 am
I think it was the first sharpening since the factory one.
What I did was :
- SM set at 30 degrees with a single rod
- put the heel of the blade on it and adjusted it until it clicked on the rod
- made my 6:1 passes from there, deburring with the knife almost flat on the stone, going upwards
It felt like the same angle as the original one, so maybe I was just a little too tilted on the rod ? I know I went straight down, no following the curve of the blade. Keeping the spine straight and perpendicular to the base.
bbturbodad
#20987
Post by bbturbodad »
Can't believe I held out so long before getting one! The Delica platform is quickly becoming one of my favorites. Strangely I only have a few lil Matriarchs, Tasman, and now this fantastic FFG SE Wharnie. Do we have confirmation that the upcoming K390 run will be released in a Wharnie?
-Turbo
#20988
bbturbodad wrote:
Wed May 27, 2020 7:15 pm
Not much wharnie-experience, but the Delica for me still is clearly the best Spyderco in its size category, and ffg SE a great choice anyway... maybe I'll get one too.. :rolleyes:
PSquared
#20989
Post by PSquared »
Centofantes two days in a row ... flat ground, thin stock, serrated wharnie - before it's time.
#20990
#20991
Translucent blue twice... ;)
VashHash
#20992
Post by VashHash »
2 very different knives today
#20993
5-by-5
#20994
Post by 5-by-5 »
Throwback Thursday
#20995
Thu May 28, 2020 8:31 am
I saw this picture and immediately in my mind I heard Julie Andrews singing the Sound of Music. :)
#20996
T-1000
#20997
Post by T-1000 »
ImageAt the beach
bbturbodad
#20998
-Turbo
Woodpuppy
#20999
Post by Woodpuppy »
Sun May 24, 2020 8:45 am
Pretty new knife, pretty old fossile I came across... :)
That’s an awesome ammonite!
Featherblade
#21000
Post by Featherblade »
Para 3
