Force To Open/Close A Blade Changes
Has anyone else ever seen this happen?
I've driven from Colorado (CO) to California (CA), then back. When I last left CO I had the blade opening friction adjusted on my Para 3's set the way I like them. When I got to CA two days later the blades had a lot more drag. The first thing I did was to make sure the steel was lubricated. It hadn't changed in two days, so I tweaked them up a bit. In the two weeks I was in CA there was no change in the friction. I drove back to CO and two days later I had to tune them up a bit again.
I could see a big change in the temperature making a difference, but the temperature in CO and CA was nearly the same. Some knives will change by taking them out of my warm pocket, using them for a bit, then once they cool off the action is different. Thermal expansion on all the different materials in the knife and the lube will make a difference.
I'm wondering if a change in altitude is what does it. I live at about 5,400 ft, (1646 m), drive up and over the Continental Divide at 11,000+ ft, (3,383 m), and stay at about 3000 ft, (914 m), in CA. Then coming back the whole process is reversed with the same result.
Any thoughts?
Bill
Any thoughts?
Bill
- VooDooChild
Re: Force To Open/Close A Blade Changes
Youre cursed.
Well, yeah, but I meant for reasons other than that. :DVooDooChild wrote:Youre cursed.
Interesting... and weird
I live at about just 430 m (= 1410 feet), but very frequently hike or run or climb (or partly drive) up to between 1500 and 3700 meters (= 4920 to 12140 feet). Climate can change a lot either concerning humidity and so on
Never experienced what you describe! Could be of course that I just pay less attention or don´t have your keen senses...
Generally and theoretically a change in altitude and by that in air pressure certainly can have an impact on "stuff". Water boils at lower temps, liquids expand more (which can even lead to problems if one has lets say an inflammation in the jaw, not noticed at low altitude, but painfull at high altitude) and so on
So maybe, just maybe, materials alter their dimensions a tiny bit in different altitudes and if items are built with very close tolerances, that could possibly have an impact?
How about changes in humidity? I used to drive from CO to Missouri a lot, and definitely noticed all kinds of wierd stuff happening once the midwest humidity hit. And going back to CO, I could practically feel the moisture being sucked from my body. Could be affecting expansion/contraction of the scale materials around the pivot, maybe?
Or maybe the constant vibration on the long drive?
- Julia
Hygroscopic lubricant? You have the tools to adjust the action to your satisfaction at both ends and the middle. You can't be any better prepared for the trip with your knife(s) than that.
Yes, I agree a drop in air pressure can make a difference. In addition to what you said, changes in humidity, ear drums, and sealed bags of potato chips can take place!Wartstein wrote: ↑Fri May 22, 2020 2:21 pmInteresting... and weird
I wonder if Larrin Thomas, PhD might chime in about the different materials. The Para 3's I took along have G10 scales. I would think they're all inert, though.
To answer Mike Blue's question, I use Break Free CLP so I don't know if it's hydroscopic.
I know that the friction increased on the blades when I went to CA, but don't remember if after adjusting them there it increased or decreased when I got back to CO.
Hmmm.
Bill
- JacksonKnives
You need to eliminate some variables for us.
Which force/part of travel are you noticing this for? Opening? Free-swinging with no lock pressure? Travel with lock pressing against tang?
Which lock type?
Did you notice a change in blade play?
Which lock type?
I live in an Equatorial climate. Inside a cool, internal air conditioned environment, my Para 3 lightweight blade drops shut perfectly all the way back into the handles. Outside in the heat & humidity, there is definitely more friction, the blade no longer drops shut all the way. So there definitely is a difference.
I think it likely that after initial use, as the lube was spread out, that gunk from manufacturing got into the pivot area and started dragging the blade. Perhaps a good cleaning? Or, it could be that the pivot has no locktite and it worked itself tight over time and use (I have had this happen with BM's, some loose, some tighter).
I've heard of a pivot getting looser with use but not tighter, at least not in such a short period of time. I'm inclined to say you've just lost your mind and need therapy and a strong medication?
Ok let's be serious and break this down. Do you take your knives apart? If so, do you also use a thread locker when you put them back together? On my Caribbeans I have polished the blade tangs and if I don't reassemble them with the washers on the right side and even flipped in the right direction it will effect pivot action, but this is felt immediately after I put the knife back together and not 2 days later.
I don't think you're seeing a drastic enough change in temp to expand the metals enough to change the tolerances...for starters the tolerances just aren't that precise, even if you went from 120+ degrees in the Mojave desert to -50 degrees in Antarctica, I don't think the tolerances are tight enough to see a difference and you said yourself you really didn't move from one climate to a drastically different one. If pocket warmth was enough then we would all experience this (ok I'm really leaning towards the "you're crazy" hypothesis).
I'm thinking there's either a perception thing going on, you've reassembled them wrong, you have crud in the pivot, or I guess you're just psycho and need electroshock therapy. You maybe shouldn't be around sharp instruments to begin with
My wife has been telling me that for years! Hahahaha! :D
I do agree with crud in the pivot.
We've found that humidity makes a big difference,
I’ve had that experience with knives. Varying levels of humidity seem to affect some of my knives more than others. In my Spydercos, I’ve had that happen with some (not all) of my compression locks and back locks mostly. I’ve experienced it even more significantly with some Benchmade axis locks, and a couple of my CRK knives (frame locks) as well.
I lived in CO for 22years, then moved to coastal SOCAL in 2000. It has to be the humidity difference. It affects everything that moves or spoils. When my wife and I visit CO now, we get nosebleeds. We aren’t adapted like we were back when we lived there.
Nose bleed certainly sounds a lot more like due to changes in altitude than in humidity to me...
Interesting! Even more so, since changes in humidity are much more likely to being experienced for most people than real changes in altitude (lets say going from a dry office-climate to a hike in a forest on a rainy day).James Y wrote: I’ve had that experience with knives. Varying levels of humidity seem to affect some of my knives more than others. In my Spydercos, I’ve had that happen with some (not all) of my compression locks and back locks mostly. I’ve experienced it even more significantly with some Benchmade axis locks, and a couple of my CRK knives (frame locks) as well.
In my life both (changes in humidity and altitude) happen a lot, but I never experienced changes in how my folders behave. And the vast majority are Spyderco backlocks.
But again, maybe I just did not pay attention or my senses are not keen enough.
- Shannon
MNOSD 0006
MNOSD 0006
I'm going to test that theory, Sal. I'm out east in Thornton and as you know we've had dry, windy weather lately. Tomorrow we're having T-storms with rain. I'm going to take the Para 3's out of the relatively dry safe and see if something changes in the next couple of days.sal wrote: We've found that humidity makes a big difference,
The thing was Dan they were tuned up just fine prior to leaving for CA. When I did re-tune them the pivot screws were still snug enough to stay put. I know what you mean about the BM's. I've got some I've tried to adjust and when you get them where you like the action the screw is just on the hairy edge of breaking free.Doc Dan wrote: I think it likely that after initial use, as the lube was spread out, that gunk from manufacturing got into the pivot area and started dragging the blade. Perhaps a good cleaning? Or, it could be that the pivot has no locktite and it worked itself tight over time and use (I have had this happen with BM's, some loose, some tighter).
Nope, I've never taken these apart. I have noticed that over a long period of time here at home the action may need a tweak, but this was pretty sudden.Evil D wrote: Ok let's be serious and break this down. Do you take your knives apart? If so, do you also use a thread locker when you put them back together? On my Caribbeans I have polished the blade tangs and if I don't reassemble them with the washers on the right side and even flipped in the right direction it will effect pivot action, but this is felt immediately after I put the knife back together and not 2 days later.
Yes, instead of free-swinging when closing these would come to a stop with the same amount of body english applied, and I had to apply a little more force to flick the blades open. So, free swinging and with lock pressure. No additional wobble in the blade, though.JacksonKnives wrote: You need to eliminate some variables for us.
Which lock type?
Bill
Well, after a few days where the weather has gone from warm and dry to cool and rainy, then back again, there’s no real change in the Para 3’s.
