Show your mods!
Re: Show your mods!
Nice job Jazz! I'm a big Wharnie fan.
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
Re: Show your mods!
boomer.52 on Instagram
Man is not consistent but in his capacity to assume and be wrong...
Re: Show your mods!
Looks great Boomer!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
Re: Show your mods!
Spyderco Delica/Mini Street Fighter 3... black peel ply G10 w/royal blue G10 liners...
Re: Show your mods!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
Re: Show your mods!
Been wanting to do this mod for a while now. Finally got around to it this Previously I had rounded the edges of the scales a little, acid stonewashed the clip and made a “mini choil” if you will, as I tend to use it as a utility knife with some fine cutting tasks where I like to pinch the blade with my index and thumb near the tip and have my middle finger up real close to that cutting edge.
Re: Show your mods!
I used a Dremel tool with a reinforced cut off wheel, diamond bits, a sanding bit, and a diamond disk for the top. Dipped in water to not ruin the heat treat. For the edge, I cut some with the reinforced wheel, diamond bits, and diamond disk. Various sandpapers and a strop for polishing the spine. Sharpened and made sure the edge was straight, and there you have it.
- best wishes, Jazz.
Re: Show your mods!
Awesome thanks!Jazz wrote: ↑Fri May 08, 2020 4:58 pm
- Haunted House
Re: Show your mods!
Justin that’s awesome!
Re: Show your mods!
I agree!
Barry
Bonne Journey!
MNOSD member 0032
Bonne Journey!
MNOSD member 0032
Re: Show your mods!
Thanks guys! Hopefully it'll be enough to tie me over until the K390 wharnie is revealed
Justin :spyder:
Re: Show your mods!
Endura straight spine mod by Razor Edge Knives. First pic is kind of a before and after type deal.
Re: Show your mods!
Now they have a Halloween/ Philadelphia Flyers look.
Re: Show your mods!
Very very crude and first mod. Testing my more budget friendlies first. Was straightening the spine on the tenacious but ran out of time. Also added a finger choil. The indent on the G10 is just a test for texturing. More to come. After work tomorrow.
Re: Show your mods!
Put a small sharpening notch in my ZDP dragonfly today. The plunge grind took up the first like, 3mm of blade and starting looking pretty wonky after sharpening. Only took about 15 minutes with a brown sharpmaker rod too! :D
Justin :spyder:
- PeaceInOurTime
Re: Show your mods!
Maxemetman wrote: ↑Mon Jun 01, 2020 7:54 pmVery very crude and first mod. Testing my more budget friendlies first. Was straightening the spine on the tenacious but ran out of time. Also added a finger choil. The indent on the G10 is just a test for texturing. More to come. After work tomorrow.
Looking forward to seeing the mods on this one!
