Brouwer Clip Placement - 2020 Catalog
hovan2yourknives
I just noticed in the new catalog that it seems like the pocket clip placement has been adjusted to provide a deeper carry. However, it is only adjusted on the lock-bar side for right-hand carry which is a little curious (if the photo is accurate). If these images are accurate...I will finally get one!
Can anyone confirm or deny that this is a CQI adjustment?
hovan2yourknives
Re: Brouwer Clip Placement - 2020 Catalog
Good eye! That's a welcome change.
- Larry_Mott
I don't have a problem with the clip as is.. Oh well :)
On a side note - how do you pronounce Brouwer? Brow, like eyebrow or Brew, like coffee?
The Meat man
I've always heard it pronounced the former. (Brow as in eyebrow)Larry_Mott wrote: ↑Sat Jan 04, 2020 2:41 amI don't have a problem with the clip as is.. Oh well :)
- Connor
Marulaghost
Brouwer is a Dutch designer.Larry_Mott wrote: ↑Sat Jan 04, 2020 2:41 amI don't have a problem with the clip as is.. Oh well :)
So Brou would be like eyebrow.
But the W should be a sharp F like Field
So it would be "Browfer"
- Larry_Mott
I thought it was the 'V' that was pronounced 'F', not the W oh well :)Marulaghost wrote: ↑Sat Jan 04, 2020 9:07 amBrouwer is a Dutch designer.Larry_Mott wrote: ↑Sat Jan 04, 2020 2:41 amI don't have a problem with the clip as is.. Oh well :)
You are correct.Larry_Mott wrote: ↑Sat Jan 04, 2020 10:42 am
Source: me, born and raised speaking Dutch.
- Larry_Mott
I have vague memories of someone telling me how to pronounce Cornelis Vreeswijk's name right decades ago :)G_shark wrote: ↑Sat Jan 04, 2020 12:40 pmYou are correct.Larry_Mott wrote: ↑Sat Jan 04, 2020 10:42 am
- Surfingringo
I would assume that the W is pronounced as V as in German?G_shark wrote: ↑Sat Jan 04, 2020 12:40 pmYou are correct.Larry_Mott wrote: ↑Sat Jan 04, 2020 10:42 am
- Larry_Mott
Volkswagen is pronounced Folkswagen. (In Germany and Sweden at least :) )Surfingringo wrote: ↑Sat Jan 04, 2020 3:39 pmI would assume that the W is pronounced as V as in German?G_shark wrote: ↑Sat Jan 04, 2020 12:40 pmYou are correct.Larry_Mott wrote: ↑Sat Jan 04, 2020 10:42 am
Same in AustriaLarry_Mott wrote: ↑Sat Jan 04, 2020 4:01 pmVolkswagen is pronounced Folkswagen. (In Germany and Sweden at least :) )Surfingringo wrote: ↑Sat Jan 04, 2020 3:39 pmI would assume that the W is pronounced as V as in German?G_shark wrote: ↑Sat Jan 04, 2020 12:40 pmYou are correct.Larry_Mott wrote: ↑Sat Jan 04, 2020 10:42 am
Marulaghost
You guys are completely correct. I had a brain fart
Well, noSurfingringo wrote: ↑Sat Jan 04, 2020 3:39 pmI would assume that the W is pronounced as V as in German?G_shark wrote: ↑Sat Jan 04, 2020 12:40 pmYou are correct.Larry_Mott wrote: ↑Sat Jan 04, 2020 10:42 am
The clip movement is an improvement, but the MXG short clip is better. The standard clip is still too long.
SCARAMOUCHE!
As part of the CQI, the standard clip was also downsized on the new version of the Brouwer. Just something I forgot to mention in my other post. :spyder:gull wing wrote: ↑Sun Jan 05, 2020 2:56 pmThe clip movement is an improvement, but the MXG short clip is better. The standard clip is still too long.
[img] https://i.imgur.com/tvLc36F.jpg [img]
Notsurewhy
I want to get one of these but I really just can't get past the green scale color.
