Replace inlay on a Vesuvius?
Richard K
Post by Richard K »
Just got a Vesuvius and while I like the knife, I'm not wild about the blue inlay. Is it possible to remove the inlay in one piece in order to use it as a pattern for replacement material. I'd like to use carbon fiber or a rosewood veneer. Any thoughts?
Blades
Post by Blades »
I suppose you could. I would wait and ask Sal what they used to hold the inlay in with. Just in case its some super epoxy or something. Good luck.
Blades
Richard K
Post by Richard K »
Thanks for the reply Blades. Yeah I'm a little reluctant to tackle it without that info. Sure would look nice with an exotic wood or CF inlay though.
Rich
Hi Richard. I imagine you could dig it out, it is glued in. You could carve a replacement, make sure it is an exact fit, then re-glue.
Tjhe shell insert is .030, make sure your replacement is no thicker.
Richard K
Post by Richard K »
Thanks Sal, I'm still working up the courage but as soon as I find a piece of suitable material (and the time) I think I'll attempt it.
Rich
