Dear Sal, a question about that floating stop pin..
What took you so long?
It seems like a drastically better design than the screwed together stop pin. I have a pretty good selection of knives with both styles of stop pins and it seems that the pivot action is significantly improved with the floating pin, or at least that the screwed pin was a source of binding or throwing the pivot area out of parallel.
Was this some random idea or did it take time for the tech to develop or something? I guess I'm curious how it came to be in the first place since it seems like such a significant improvement it seems like a no brainier and surprising that it wasn't part of the design all along.
- Larry_Mott
Re: Dear Sal, a question about that floating stop pin..
Speaking strictly for myself it is often that the obvious solution takes time to come to you :)
- Location: “Beam me up Scotty, there’s no intelligent life down here.”
Amen! I have often in life had an insight that was brilliant, after I’d been doing something the hard way for years. Be interested in Sal’s answer to this.
:spyder: Shaman REX 45, Smock, Baby Jess Horn CE, Spydiechef, Schempp Bowie,Ti Fluted Military, Titanium Military, Native S30 V and G10, PM 2 in S35VN, and S110V, Manix 2 LW BD1 and SPY 27, Sage 5, Positron black CPM S30V, Chaparral w/Raffir Noble scales, SuperLeaf VG 10, Ladybug H1, Dragonfly 2 in ZDP 189 and Superblue/420J1 and H1, Delica in ZDP 189, Clipitool Standard, the Cook’s knife VG10, Santoku, paring and utility knives, all in MBS 26. :spyder:
I agree. Time and experience is usually the result...
MNOSD 0006
It's too bad Sal lacks your keen intellect otherwise he could have really done something with his life and accomplished something.
Evil D wrote: ↑Wed Nov 20, 2019 2:16 pmWhat took you so long?
It's a tongue in cheek way of saying it's a fantastic design and I wish it happened sooner. You can put your torch and pitchfork away now.
Watch it.wsdavies wrote: ↑Wed Nov 20, 2019 4:04 pmIt's too bad Sal lacks your keen intellect otherwise he could have really done something with his life and accomplished something.
- curlyhairedboy
I'm a fan of the floating stop pin. The locking triangle is a hard thing to adjust, as each part is affected.
- JonLeBlanc
Indubitably lolLarry_Mott wrote: ↑Wed Nov 20, 2019 2:45 pmSpeaking strictly for myself it is often that the obvious solution takes time to come to you :)
I'm really just curious if this design was part of the plan all along, or if it wasn't possible 10 years ago or if it was just a lightbulb idea moment.
I think it was an “Ah ha!” Moment.
I also like the floating lockbar pivot on the native 5 and chief.
Agreed! :)Larry_Mott wrote: ↑Wed Nov 20, 2019 2:45 pmSpeaking strictly for myself it is often that the obvious solution takes time to come to you :)
The ability for the blade stop to take a significant amount of load and NOT dislodge is an imperative of most folding knives. So, before we had a better understanding of materials, it was probably safer to screw it in. Just guessing.
I think there continues to be a mentality that more screws = more strength. Where as some knives like the K2 may prove that unnecessary with only two screws holding it together (and that sexy as **** "squished" stand off).
- ChrisinHove
I think you hit the nail on the head, there. Simplify and add lightness, as paraphrased by Colin Chapman of Lotus cars
We're always working on CQI improvements. To go full production with any new idea takes time and planning. Tolerances are very close and must be carefully planned for while making many knives and many models. Some things we're quick to do and some are cautiously moved forward.
Which models sport this stop pin?Evil D wrote: ↑Wed Nov 20, 2019 2:16 pmWhat took you so long?
Doeswhateveraspidercan wrote: ↑Thu Nov 21, 2019 3:13 pmWhich models sport this stop pin?Evil D wrote: ↑Wed Nov 20, 2019 2:16 pmWhat took you so long?
Newest Military was first I believe, now the Caribbean, Shaman and Para 3 all have it. I'm sure I'm leaving some out.
I find it interesting that, for whatever reason, the Para 3 LW does not have it.
I haven't had one apart... could it be hidden inside like the Caribbean?
