recently i aquired the new paramilitary (new in holland that is), besides from the obvious good looks and probable usefulness it had quite a lot of play on the pivot point,not on the compression lock itself.
i returned to my wholesaler only to see that all of the paramilitaries he had had the same problem,some more some less.
because of me liking the design i left with one i thought had the least play,but still,has anyone encountered this problem also?
paramilitary question
- king-of-mars
kwak
A T8 torx driver or a 3/32 inch allen wrench will fit the pivot screw if you want to tighten it. I do recall reading something about there being play in the first production run Paramilitaries. A T6 torx driver fits the other assembly screws.
"it is better to be hated for what you are, than to be loved for what you are not."
Edited by - king-of-mars on 7/11/2004 11:40:33 AM
