The Iconic Spyderco Hole Question
Termite Toothpick
Re: The Iconic Spyderco Hole Question
Post by Termite Toothpick »
sal wrote:Hi Daknight,
Welcome to our forum.
Thank you Sir,
It is an honor!
Derek
Dragonfly G-10, Blurple PM2, Para3, Jani-Song, Dragonfly2 ZDP-189, Lil' Native, Chaparral LW, Delica WC HAP40, Para3 M4, HH UKPK S30V, Para3 LW, Para3 LW M390, Meerkat V-TOKU2, M4 Sage 5 LW, Urban Ivory Damasteel, Leaf Storm
:bug-white-red -Derek
ZrowsN1s
Post by ZrowsN1s »
diamond needle.jpg (12.46 KiB) Viewed 1160 times
I run an ultrafine needle file from my KME set up around the inside edge. I find most spydies don't need it. But I've had one or two that scratched up my fingernails before I filed them down a little.
freebird610
Post by freebird610 »
Spydergirl88 wrote:Sandpaper wrapped around a wooden dowel
This I use 400 grit and it works pretty well. A wooden dowel or I use a plastic marker. Just don't use your finger. You will round off the edges too much. I do this to all my Japan spydies. I don't feel the Golden ones need it but the Japan ones are sharp on the edge. Just keep checking as you go and stop when you get it to your preference.
FCM415
Post by FCM415 »
I like it rough :eek:
Jonathanp8219
Post by Jonathanp8219 »
A knife sharpener solved this problem about a week ago by rolling up a bit of sandpaper, and moving it gently back and forth inside the spider hole. It only took him two minutes and the spider hole was still prominent but a bit less sharp. So no grip was lost and it feels perfect on your thumb. It was alot easier than you would think.
