Show your Mule
dubya3
Re: Show your Mule
#1041
Post by dubya3 »
farnorthdan wrote:I think it looks good Niles, should make a real nice work knife. You could always pick up a 2nd and give it another go.
Agreed, it looks good. Nice work!
Cory
Upgrading to a Ti ATR once I sell my stainless ATR :)
DougC-3
Re: Show your Mule
#1042
Post by DougC-3 »
I'm no expert on the subject, but it looks great to me as is.
Note to self: Less is more.
NiallRiv
Re: Show your Mule
#1043
Post by NiallRiv »
Finally learned how to post pics! Ive "handled" 6 mules to date and I get some more pics up soon. Heres one that I already had pictures of. Scales are Honduran Rosewood (choose this wood after seeing Black Beards desk in a museum made from the same wood) Image
farnorthdan
Re: Show your Mule
#1044
Post by farnorthdan »
Thats beautiful Niallriv, looks like it would be very ergonomic in hand.
NiallRiv
Re: Show your Mule
#1045
Post by NiallRiv »
:D Thank you Farnorthdan! Every one I make, I learn a little more from. This one, in my hand, honestly feels a little thin during prolonged use.
SpeedHoles
Re: Show your Mule
#1046
Post by SpeedHoles »
Just got it all set-up and ready to use!
New sheath from glockcrazz, with a Spyderco G-clip. Nice & small footprint and great retention.
Halpern 5 scales in FG.
Going back to Caly.
farnorthdan
Re: Show your Mule
#1047
That looks real nice speed, that sheath rocks, need to pick a couple of those up.
Here is my latest MT, SB and its hair splitting sharp right from the box...
SpeedHoles
Re: Show your Mule
#1048
farnorthdan wrote:That looks real nice speed, that sheath rocks, need to pick a couple of those up.
Thanks!
I'm getting ready to order another of these sheaths in orange that I'll use with this FG/4V, then swap this grey to use with my SB Mule. :)
Going back to Caly.
farnorthdan
Re: Show your Mule
#1049
I like that plan, should match the caly 3 & 3.5 scales nicely.
phillipsted
Re: Show your Mule
#1050
Post by phillipsted »
Wow, NiallRiv! Beautiful stuff. I love that H.Rosewood burl. It is almost impossible to find these days in boards of larger size. When you do find it, the dealers want an arm and a let for it. It really makes the knife, though - the swirling grain is wonderful.
I also love your contouring. Nice work. Looks like it would be very comfortable in hand.
Cheers!
TedP
BTG
Re: Show your Mule
#1051
Post by BTG »
NiallRiv wrote:Finally learned how to post pics! Ive "handled" 6 mules to date and I get some more pics up soon. Heres one that I already had pictures of. Scales are Honduran Rosewood (choose this wood after seeing Black Beards desk in a museum made from the same wood) Image
Very cool....what did you use to bring that shine back after all the contouring, just finished some Burlwood ones, and look great when wet, but chalky when dry...first attempt ..don't know, oil ? sealer ? buff with dremel, I don't know what works.
noseoil
Re: Show your Mule
#1052
Post by noseoil »
Try Danish oil & wet sand from 220 up through 800 grit paper. Wipe each coat & let dry completely before changing grits. After the 800 is dry, use a small amount of oil & rub it into the wood, wipe it off, let it dry & then do again. Takes a lot of time but gives a nice, deep finish. The oil fills in the small scratches & gives a sheen, but don't let it dry gummy or wet. Needs to be wiped off & completely dry between coats to look good.
elmeringalo
Re: Show your Mule
#1053
Post by elmeringalo »
My mules, by the moment
No por mucho tempranar, amanece mas madrugo
Xplorer
Re: Show your Mule
#1054
Post by Xplorer »
Here's my Mule 21 with the new handle and sheath I made for it.
@ckc_knifemaker on Instagram.
Train
Re: Show your Mule
#1055
Post by Train »
Xplorer wrote:Here's my Mule 21 with the new handle and sheath I made for it.
Very good job! I like how all the parts fit together and it goes very well with the sheath.
Xplorer
Re: Show your Mule
#1056
Post by Xplorer »
Thank you Train, I appreciate the kind words! :)
Train
Re: Show your Mule
#1057
Post by Train »
Here is another Mule that I have completed. I guess it was seven years between the first Mule and this one!
It is MT19 with PSF27 on the blade and briar/cocobolo on the handle.
jabba359
Re: Show your Mule
#1058
Post by jabba359 »
That's a beautiful Mule, Train. I like the contrast between the two woods you used on the PSF27. That single mosaic pin looks classy as well.
-Kyle
:bug-red
http://www.spydiewiki.com
NiallRiv
Re: Show your Mule
#1059
Post by NiallRiv »
I sanded through 1500 I believe and then did maybe 10-15 coats of Tru-Oil dunked in a jar, with a light sanding with 0000 steel wool every 3-4 coats. Finished with a couple vigorous renaissance waxings.
Train
Re: Show your Mule
#1060
Post by Train »
Just finished the next one. You only need to get me going....
This one is still the same MT19 with SPF27 with pieces of bubinga and olive on the handle. Actually picked some left-overs from another project I just could not bring myself to throw away. Thus that shape: had to spend a bit more time fitting the pieces together. And there some small cracks in the olive that came up close to the end: that's a wood burl for you! That of course has no affect on the integrity and using the knife - filled it with superglue anyway to prevent any dirt accumulation.
Thank you for looking!
