Want first Salt H1 knife, help me decide...
- JediKnight86
**** all. I'm back on :spyder: 's with my new orange Military on the way. I've decided it's time to finally get a Salt. I really want to try the H1 and beat the crap out of it and leave it at the bottom of my pool :D
Which is the fav around here?
Hi my name is Alex and I'm a Spyderholic :D
- Lord vader
Read lionstooth review,this one says it all.http://spyderco.com/forums/showthread.php?t=37647 Post#1
- white cloud
I am a huge fan of the salt 1 but could see going with the pacific salt if you like to cary a larger blade.
Endura ZDP-189 CE | Endura Wave CE | Salt 1 PE | Centofante 3 PE | Tenacious PE | Tenacious SE | MT02 Second | MT03 | JD Smith | Caly 3 ZDP-189 CF | Bill Moran | Military | Tasman PE | Stretch 2 CF | Endura | Delica | Dragon Fly
- spyderHS08
I love my salt one, If you get one you wont regret it! :cool:
39 & counting...
Dodo!
Dodo!
I really like the Mariner Salt. It doesn't get a lot of attention on here, but I really like it a lot.
Here is a review I did a while back on it:
http://www.spyderco.com/forums/showthread.php?t=36749
I'll probably pick another H1 blade this summer, this time a PE model.
- JediKnight86
if length is not an issue, i'd say serrated pacific salt.
if length is an issue, serrated salt I.
yellow, of course... :D
a tasman SE is also a great idea... also love the aqua salt as an EDC fixed blade...
you'll probably find that serrated H1 holds a much better edge than PE H1... until you get a couple years of work hardening in on the PE...
:spyder: :spyder: :spyder:
- JediKnight86
What do you mean work hardening? I understand why serrated would hold a better edge because of the principles of the teeth making less work for the cutting edge, but they're limited in uses.clovisc wrote: you'll probably find that serrated H1 holds a much better edge than PE H1... until you get a couple years of work hardening in on the PE...
Get a Tasman!!!
My Spydies: Sharpmaker • Tasman Salt • Saver Salt • Ladybug Hawkbill Salt • Salt 1 • Blue/Gray Meerkat • Burgundy Meerkat • Manix2 Ltwt Translucent Blue • Manix2 Ltwt Blacked Out • Manix2 Backlock • Ladybug 1 Red • Blue UKPK • Tusk • Blue Lava • Dog Tag • Bug • Honeybee • Grasshopper • Stepped Ti Chaparral • McBee • AEB-L Urban
H1's edge holding properties actually improve as you stress the steel through everyday use. something about the molecular bonds? sounds crazy, but its true... you can search the forums here for more sophisticated explainations.JediKnight86 wrote:What do you mean work hardening? I understand why serrated would hold a better edge because of the principles of the teeth making less work for the cutting edge, but they're limited in uses.
i believe that the extra amount of work that goes into producing the serrated edge... as well as the rock salt (and to some extent, the aqua salt), seems to work-harden these blades more before they arrive, ready for your pocket. meaning that they will hold an edge longer, and give higher performance.
i've got some salts with 3 and 4 years of hard use on them -- they're incredible knives. :D
a well-maintained serrated edge can do anything a plain edge can do.
serrated H1 can also cut open cans. which seems to help expediate work hardening... :D
welcome to the crazy, awesome world of H1.
- JediKnight86
- JediKnight86
If onlyclovisc wrote:you could always fix your 'which salt to buy?' dilemma by buying them all... :D
Ok thanks for the info! When I say limited I'm talking about mostly bushcraft things. Serrated isn't great with wood, like making steaks or spears, can't do forward angled push cuts especially with the serrations being on the inside egde.clovisc wrote:H1's edge holding properties actually improve as you stress the steel through everyday use. something about the molecular bonds? sounds crazy, but its true... you can search the forums here for more sophisticated explainations.
