UKPK Magnacut?
Re: UKPK Magnacut?
One or very were available at coutellerie tourangelle in Europe but almost immediately gone, sadly I was too slow.
Re: UKPK Magnacut?
Mine was delivered yesterday. A small amount of pocket time already but not used yet.
I will swap the yellow FRN over for some Titech ones once I get the chance.
One small thing I have noticed is that the edge bevel appears to start further away from the plunge grind with each model, about 2mm in this instance.
Re: UKPK Magnacut?
Before I got a green UKPK salt a couple years ago I had looked around for a yellow one in LC200N and couldn’t find one. I just got a yellow UKPK salt from SMKW, listed as LC200N but delivered as Magnacut, so I think your assumption is good.Buddafucco wrote: ↑Wed Jul 03, 2024 5:42 pmI'm assuming any Yellow PlainEdge UKPK's that show up after now are going to be the long awaited MagnaCut UKPK's. But buyer beware, some dealers could still have new old stock on hand.
Re: UKPK Magnacut?
Waiting for these to show up at Canadian retailers. So far they all still show LC200N.
Re: UKPK Magnacut?
Alright, now we’re cooking with gas! The Siren and the UKPK are the two designs I’m most interested in.
Re: UKPK Magnacut?
I believe the Siren is discontinued. Quite a shame as the back lock was excellent and the handles were grippy with just enough contour. The only issue I had was with the blade contacting the lock bar and creating a flat spot if you flick it closed.
Re: UKPK Magnacut?
The Siren is fantastic. I bought a couple of spares and it’s the only model I have in the fancy CF/s90v model. If you want one don’t wait, they aren’t making any more.
Re: UKPK Magnacut?
My favorite Spyderco design of all time.SchoonerBum wrote: ↑Tue Aug 06, 2024 6:34 amThe Siren is fantastic. I bought a couple of spares and it’s the only model I have in the fancy CF/s90v model. If you want one don’t wait, they aren’t making any more.
Shame on the blade rap issues, but if you close it fairly carefully, then you should be fine.
I too have a few of these Sirens, and the S90V model has the tightest tolerances of any Spyderco backlock I ever had.
Re: UKPK Magnacut?
I see that these have finally shown up and sold out at Canadian retailers. I got mine though, and am very happy with it. Ridiculously light for its size, and the Slip-it mechanism is fantastic. It was slicing tissue paper after a couple swipes on a UF rod.
Re: UKPK Magnacut?
$100.13 at National Knives. ETA Wednesday. Establish an account for discounted price.
Re: UKPK Magnacut?
A friend picked up my PE Magnacut UKPK from the po box and has already cut open her thumb.
Re: UKPK Magnacut?
I see they've bonded nicely.
Re: UKPK Magnacut?
Availability in Europe is still a sad story... But hey, it is being sold for 180€ on eBay.
Re: UKPK Magnacut?
Hi folks. Oh WoW, the knife's already been released and shipped to some of you. I just realized they put you in the hole for 4 years if you so much as carry anything over 3inch or with any type of lockable blade, so thinking this might be the one blade to rule them all and still be supposedly legit. Other than the legality of it being in UK, is it worth it as a knife? at only 49g or whatever, I'm just afraid that applying some pressure/cutting force the blade might pop out backwards through the handles. is it fairly sturdy? also in order to close it do you at least have to apply a bit of pressure? Last but not least, it's out of stock everywhere. CHeers!
Re: UKPK Magnacut?
Dear JOHN7UP:
Stay safe,
Mike
Stay safe,
Mike
Re: UKPK Magnacut?
There is no way you are going to break the knife. FRN is stronger than G10 and the pivot is hardened steel. The blade will snap long before the rest gives way. I love this knife.JOHN7UP wrote: ↑Fri Dec 27, 2024 2:33 amHi folks. Oh WoW, the knife's already been released and shipped to some of you. I just realized they put you in the hole for 4 years if you so much as carry anything over 3inch or with any type of lockable blade, so thinking this might be the one blade to rule them all and still be supposedly legit. Other than the legality of it being in UK, is it worth it as a knife? at only 49g or whatever, I'm just afraid that applying some pressure/cutting force the blade might pop out backwards through the handles. is it fairly sturdy? also in order to close it do you at least have to apply a bit of pressure? Last but not least, it's out of stock everywhere. CHeers!
Re: UKPK Magnacut?
It does require a bit of pressure to close. Mine (UKPK Salt) also has a half-stop. It is definitely recommended that when using it, you always use the choil when cutting. It's the natural position to hold it in, anyway.
Re: UKPK Magnacut?
Ugh. Still waiting for this to be available…
Re: UKPK Magnacut?
Quid hoc ad aeternitatem
Re: UKPK Magnacut?
I wish this knife really was that light yellow in these pictures, but of course, it isn't.RugerNurse wrote: ↑Mon Dec 30, 2024 4:59 pmGP Knives has it in stock
https://www.gpknives.com/spyderco-uk-pe ... ellow.html
