Spymyto is hot!
- Buddafucco
Re: Spymyto is hot!
•• Beau
- nonstainless
Re: Spymyto is hot!
Expensive? Maybe. Brittle? Definitely not. I'm sure spyderco wouldn't make it happen if there were any issues regarding the hollow grind M398.
Actually I feel like the exact opposite - excited to see a hollow grind spydie (Ilove my GB2) and M398 is an extra bonus. Depending on the bte thickness spymyto could be a good cutter despite the 4mm stock
Take heed therefore that the light which is in thee be not darkness. L11:35
Re: Spymyto is hot!
What I'm saying is that is is not hollow ground, and I was wondering why. It's not, I've asked to every people that got one already and it's flat groundnonstainless wrote: ↑Thu May 02, 2024 11:32 amExpensive? Maybe. Brittle? Definitely not. I'm sure spyderco wouldn't make it happen if there were any issues regarding the hollow grind M398.
Actually I feel like the exact opposite - excited to see a hollow grind spydie (Ilove my GB2) and M398 is an extra bonus. Depending on the bte thickness spymyto could be a good cutter despite the 4mm stock![]()
Edit : I see the confusion, when I wrote Myto I was referring to the original Myto, not the one Spyderco made
MNOSD member 004* aka Mr. N5s
Re: Spymyto is hot!
Probably some of both. Some sites had pre-orders, others havent. For the sites that did not have pre-orders, I heard May 3rd was the earliest anticipated date a distributor was expecting them, so the non-preorder sites will probably start dropping them in the next day and coming weeks. Keep your eyes peeled and signup for notifications from all the knife sites.
- RadioactiveSpyder
Re: Spymyto is hot!
The huge gap between the lock bar and the scale really bothers me for some reason. The Drunken and a few other models also have a wide gap, as does the Lionsteel Myto. I don’t understand the purpose of cutting them like that, especially when I’ve seen other models from Spyderco and other manufacturers having much tighter ones. Seems like they would capture a lot more lint and gunk this way. It’s a great looking knife otherwise.
Re: Spymyto is hot!
I4ve noticed that molletta's designs all have that in common when it comes to framelocks. lionSTEEL made several integrals so I do not think going thinner on the cut would be hard for them. Could be a designer's choice ?RadioactiveSpyder wrote: ↑Thu May 02, 2024 12:19 pmThe huge gap between the lock bar and the scale really bothers me for some reason. The Drunken and a few other models also have a wide gap, as does the Lionsteel Myto. I don’t understand the purpose of cutting them like that, especially when I’ve seen other models from Spyderco and other manufacturers having much tighter ones. Seems like they would capture a lot more lint and gunk this way. It’s a great looking knife otherwise.
Re: Spymyto is hot!
The gap was the biggest hurdle for me to get over before giving Lionsteel a chance.RadioactiveSpyder wrote: ↑Thu May 02, 2024 12:19 pmThe huge gap between the lock bar and the scale really bothers me for some reason. The Drunken and a few other models also have a wide gap, as does the Lionsteel Myto. I don’t understand the purpose of cutting them like that, especially when I’ve seen other models from Spyderco and other manufacturers having much tighter ones. Seems like they would capture a lot more lint and gunk this way. It’s a great looking knife otherwise.
I'm still not sure I like it cosmetically, but after several years of carrying and using a Large LionSpy and SR1Ti, I've never found it to present any functionality issues or cause an unreasonable accumulation of debris.
It also looks way bigger in pics than it does in person, in my opinion anyway.
- Buddafucco
Re: Spymyto is hot!
•• Beau
- Buddafucco
Re: Spymyto is hot!
G&R Tactical (coupon code???)... https://www.gandrtactical.com/SpydercoL ... _3839.html
Maybe code?: KNIVES
Edit: Out of stock
Maybe code?: KNIVES
Edit: Out of stock
•• Beau
- Buddafucco
Re: Spymyto is hot!
•• Beau
Re: Spymyto is hot!
Thanks Buddafuco, got one from G&R!
Re: Spymyto is hot!
I also got one from G&R, $207 with the code.
I appreciate your hard work and dedication, Buddafucco.
- Buddafucco
Re: Spymyto is hot!
G&R Tactical ( Maybe Coupon Code: KNIVES )... https://www.gandrtactical.com/SpydercoL ... _3839.html
KnifeHub... https://www.knifehub.com/product-page/s ... e-c265mtip
KnifeWorld... https://knifeworldwv.com/product/spyder ... -c265mtip/
North River Outdoors... https://www.northriveroutdoors.com/prod ... el-spymyto
Nashville Tactical Lounge (Priced a little higher)... https://nashvilletacticallounge.com/spy ... -c265mtip/
Edit: Out of stock
Edit: Out of stock
•• Beau
Re: Spymyto is hot!
I got one from KnifeWorld. Thank you Buddafucco for your diligence.
Re: Spymyto is hot!
Just another data point: I picked up a SpyMyto at the SFO yesterday and the blade is flat ground.Ramonade wrote: ↑Thu May 02, 2024 12:01 pm
What I'm saying is that is is not hollow ground, and I was wondering why. It's not, I've asked to every people that got one already and it's flat groundI was excited too, only for the high hollow grind + M398 combo !
- Buddafucco
Re: Spymyto is hot!
Back at G&R Tactical ( Maybe Coupon Code: KNIVES )... https://www.gandrtactical.com/SpydercoL ... _3839.html
Edit: Out of stock
Edit: Out of stock
•• Beau
Re: Spymyto is hot!
GONE!Buddafucco wrote: ↑Fri May 03, 2024 10:08 amBack at G&R Tactical ( Maybe Coupon Code: KNIVES )... https://www.gandrtactical.com/SpydercoL ... _3839.html
