LC200N / Caribbean SE torture test gauntlet of death
Re: LC200N / Caribbean SE torture test gauntlet of death
#81
tonijedi wrote:
Sun Mar 15, 2020 3:51 am
Thank you for the test.
Also, that's an expensive bone :D
I put it in a Ziploc bag in the fridge for future testing
At least until it spoils.
I need a SE Pacific...for SCIENCE
Jazz
#82
Post by Jazz »
With rolls like that, I personally would have steeled them backwards (on an actual grooved steel) to straighten before sharpening. That's just me. It might cause the rolls to break off. I don't know.
- best wishes, Jazz.
Woodpuppy
#83
Post by Woodpuppy »
Evil D wrote:
Sun Mar 15, 2020 4:54 am
Go set it near an ant hill. They’ll pick it clean and the bone will last for nearly ever.
#84
every time this thread comes up, i get a slight panicky feeling of needing a caribbean. thanks for sharing your testing with us. :)
Sumdumguy
#85
Post by Sumdumguy »
Sun Mar 15, 2020 2:29 pm
Never go against your gut! :p
-Thomas Jefferson
#86
Well then I'll try to post more often :D
Sonorum
#87
Post by Sonorum »
Evil D wrote:
Sun Mar 15, 2020 3:19 pm
Same here you bastard :p Everytime I talk myself out of it, this thread pops up. You might want to talk with Sal about royalties. How thick is the Caribbean behind the edge? Just at the tops of one of the big scallops on say the middle of the blade? I'd curious to compare it to my Endela.
Perhaps you can test the glass fibre "carpet" that you use when building foundations for building. I have no idea what it's called in english but it's absolute death to the sharpness of knife blades. Or fibre glass insulation, that's nasty as well.
/ David
Pancake
#88
Post by Pancake »
You are MADMAN!
But if it is for science, go ahead :D
#89
Sonorum wrote:
Mon Mar 16, 2020 1:02 am
I'm not sure what that is either but I think I have some old carpet scraps rolled up in the garage I can cut up. I also plan on getting some car battery terminals (very thick copper).
Thickness behind the edge is kinda hard to measure. It's obviously thicker than a PE but then the bevel is also twice as wide but only on half the blade so I'm not even sure how you'd compare those numbers. I would expect that if you measured at the same height as a typical PE bevel, a SE bevel is thinner. The SE bevel being so wide, I also look at them as a ghetto convex since they transition into the blade grind much smoother than a 30 inclusive PE bevel does. I also can't really measure my Caribbeans since they're both heavily sharpened at this point so the numbers wouldn't really be comparable to other knives. Maybe we should add SE to the behind the edge database just to compare those edges amongst themselves.
#90
Pancake wrote:
Mon Mar 16, 2020 1:14 am
You are MADMAN!
I just think the big question still is how does LC compare to H1, that debate will never die so however cool these tests are people will still wonder how H1 would handle them.
Sonorum
#91
Post by Sonorum »
Evil D wrote:
Mon Mar 16, 2020 4:22 am
Yeah I could have clarified that it is a serrated Endela that I was looking to compare.
/ David
#92
Food prep? How about a big'ol pickle for some burgers :cool:
It is really only limited by how steady your hand is. Would I choose this over a kitchen knife? Heck no, but I'm bored and it honestly cut better than a crappy half dull kitchen knife. The serrations made short work of the rind and it would even push cut through no problem. It would slice as thinly as you're able to slice.
#93
Evil D wrote:
Sun Mar 29, 2020 3:07 pm
... You´re really a man of his word, David! :D viewtopic.php?f=2&t=86214#p1407190
#94
Sun Mar 29, 2020 3:11 pm
I get pretty passionate about things I really believe in. I truly believe this knife and steel is the best EDC available right now. LC/SE is magical. I'm convinced this knife can't be beat, at least until another design comes that dethrones it.
#95
Evil D wrote:
Sun Mar 29, 2020 3:26 pm
I really should get and try one... you know that I became a believer in ffg SE, and the Caribbean has a lot more features I really appreciate.
Not much to NOT like here:
Would prefer a backlock, but the comp. lock is just fine too in most scenarios, and a bit more PE portion towards the tip, but that´s about it.
Monty
#96
Post by Monty »
As much as I love this thread I wish we had more knives in serrated lc200n and another steel to directly compare. The native 5 is the only one that comes to mind.
Sumdumguy
#97
Post by Sumdumguy »
It is a magnificent thing, this knife. I am waiting on my blade to come back. A few more months, probably.
In it's absence, I have been impressed with the Ulize. But, I miss my Caribbean...
-Thomas Jefferson
#98
Monty wrote:
Mon Apr 06, 2020 6:12 pm
Yeah it's a bummer I don't have a more direct comparison in H1. I could do all these tests with a Pacific and I guess try to ignore the difference in slicing, some of that stuff wouldn't cut much different in a hollow grind but the tire and tree branches and drywall may not slice as well.
I don't blame them for sticking with H1 in the Japanese Salts, they're established and proven models in a familiar steel for those who use those knives for professional jobs. I hope they end up making a lot of the Golden models in LC200N.
#99
Sumdumguy wrote:
Mon Apr 06, 2020 6:41 pm
Come back from where?
I really wish they would have done a SE Ulize. That knife would be a monster in full SE and it might dethrone every other folder I carry. One of my dream knives would be a SE Ulize Salt with a slightly taller blade height in FFG/LC200N, with rounded/contoured FRN bidirectional scales in screw together construction like the Native 5 Salt. A guy can dream I guess.
Sumdumguy
#100
Post by Sumdumguy »
Evil D wrote:
Tue Apr 07, 2020 10:35 am
To a very special friend ;)
As for the Ulize, the blade shape makes SE less necessary. Infact, it's probably my new favorite blade shape. Truly a beast, fiercely competing with the Caribbean.
-Thomas Jefferson
