Bloke,Bloke wrote: ↑Tue Mar 06, 2018 11:52 pmI’ve been playing with Luong’s knife for a month now and I’m enjoying Vanax SC with this particular heat treat immensely.
The knife came finished at a rough guess on a 120grit belt, hand sharpened to 3000grit, I believe and sharp. A section of the blade near the heel freely whittled free hanging hair.
That’s it for now but I’m not done yet and there’s still more to come.
If anyone has anything at all they’d like to see me try with the knife please feel free to suggest it.
Thanks for testing and composed an excellent write up. Also appreciate the details on edge geometry, sharpened dps and side-to-side perf testing with s30v&s90v. Your finding concurred with others & my on aspect: Edge retained shaving sharpness after extended corrosion test highlighted vanax's key attribute - compare to edge of normal stainless steel blade would lose its sub micron apex by oxidation.
IME: Edge retention submicron to ~3-5 microns apex width, for steels with 10+% carbide volume+good ht+hardness, would be similar. Vanax seems to has finer carbide (I don't have appropriate etchant to verify with microscope), perhaps translated to better/easier sharpening response than S*0V steels. Pressure/slice cuts at 5-20um apex width - coarser + more carbide s90v would out performs vanax. Vanax should win over s*0v on impact & lateral cuts/chops.
I concurred with your assessment (vanax) 'an awesome steel'.
** test params suggestion **
1. Sharpen edges only (or ended) with diamond plate. Reason: ime - strop refined the apex however weakened it at some degrees.
2. Pressure cut and chop (2 diff edge section) bamboo toothpick. This will test lateral stability and impact toughness of edge.
Thanks,
==Luong
