Cru Wear Centofante III !
Hopsbreath
Re: Cru Wear Centofante III !
#61
Post by Hopsbreath »
Evil D wrote:
Sun Sep 08, 2024 4:57 pm
Hopsbreath wrote:
Sun Sep 08, 2024 3:52 pm
Evil D wrote:
Sun Sep 08, 2024 6:38 am
It's hard to tell even in videos but the reflection on the blade sure looks flat. But, the hollow grind on my Ayoob sprints were all way less hollow than my original so it may just be less pronounced. Mine is also due to arrive tomorrow so we'll see.
If you’re talking about the sprint Ayoob in Cruwear, those aren’t hollow grinds, they’re saber. I had mine reground to hollow and it was a world of difference.
The Cruwear sprint is hollow, however small it may be, I sharpen the back side of mine FLAT on a stone and you can see where scratches are only on the edge and top shoulder of the grind. It may be so small it doesn't matter in performance but you can see it after sharpening the way I am.
I won’t argue your sharpening results, they look convincing enough. Spyderco calls it saber in their own specs though.
https://www.spyderco.com/catalog/detail ... rade-/2314
#62
Hopsbreath wrote:
Sun Sep 08, 2024 5:23 pm
I think the confusion here is due to Spyderco not specifying in the specs chart. There are flat saber grinds and hollow saber grinds. "Saber" is in reference to the height of the grind in relation to the blade. A saber grind does not span the full height of the blade. There are also full flat grinds and full hollow grinds. As the name implies, these grinds do span the full height of the blade.
In this case, the Ayoob sprint is a hollow saber grind. Jury is still out on the Centofante 3 sprint though.
Hope that helps. :respect :bug-white-red
Hopsbreath
#63
Mushroom wrote:
Sun Sep 08, 2024 6:25 pm
It is confusing because they spec other “saber” grinds as “hollow” like the Bradley folders. I’ve always taken that to mean the saber is flat and the hollow is hollow. What does that mean for the Centofante 3? Who knows, but at least an apples to apples comparison is possible with the VG-10 version.
prndltech
#64
Post by prndltech »
Evil D wrote:
Sun Sep 08, 2024 10:15 am
prndltech wrote:
Sun Sep 08, 2024 10:11 am
R100 wrote:
Sat Sep 07, 2024 10:22 pm
prndltech wrote:
Sat Sep 07, 2024 7:59 pm
Mine should arrive Monday and if it’s not a hollow grind… I’ll be returning it.
Please let us know when you get it. This is the key for me too.
Dan
Of course… Evil D or someone else might beat me to it though!
It'll be evening after work before I get my hands on it :worried
Tracking says tomorrow now :-||
MNOSD 0006
Buddafucco
#65
Post by Buddafucco »
•• Beau
Buddafucco
#66
White Mountain Knives (Not on the Dealer Locator list??)... https://whitemountainknives.com/exclusi ... e-c66cfp3/
•• Beau
#67
prndltech wrote:
Mon Sep 09, 2024 8:03 am
Dan
Sitting in my mailbox while I'm stuck at work 😫
#68
Can confirm that it is a screw pivot and is a flat saber grind.
First impressions besides that are fit and finish are superb. Perfect centering, lock bar is flush opened and closed, very tight lock up, no chips around the holes as can be an issue with CF scales (and they appear to be solid CF not laminate). The edge is extremely sharp but does have a bit of a flat spot just below the bug. Opening action is smooth, no weird gritty feeling. The thumb hole edge is very crisp which I very much prefer but that may be a negative to those who like a smoother hole edge.
I don't want to over hype this knife but this to me seems like the quality of knife that Seki were making back in the early 2000s. It's definitely on par with my nicer vintage micarta models.
The blade grind is a real bummer. I haven't decided if that's a deal breaker or not. It's still an extremely thin blade. I'm seeing about 0.0225 behind the bevel on my calipers.
aicolainen
#69
Post by aicolainen »
It's very cool that they've made the effort to CQI the construction of this old (I wanna say) sleeper. Hope it means we'll see more variants in the not so distant future.
It would be a shame if the hollow grind is a bygone feature though. Sure hope the flat grind is limited to this exclusive.
Buddafucco
#70
•• Beau
#71
Evil D wrote:
Mon Sep 09, 2024 1:45 pm
Very nice! PB washers or nylon? This looks a lot like the Seki G10/Pakkawood knives so I'm assuming it's probably the same factory using PB washers.
Looking forward to your pics! Mine is in the mail.
#72
abbazaba wrote:
Mon Sep 09, 2024 2:15 pm
PB, and super thin. Not much gap between blade and liner, I can only see them by shining a light down in there and seeing the coldish reflection.
#73
aicolainen wrote:
Mon Sep 09, 2024 2:00 pm
It does seem to be a dying feature, even the classic stainless Police is no longer hollow ground.
cabfrank
#74
Post by cabfrank »
When are you going to take it apart? 🤣
p_atrick
#75
Post by p_atrick »
A little off-topic, but I find the reluctance to do a deeper hollow on blades coming out of Seki to be a little worrying. I am really looking forward to the HP Delica, and a deep hollow (or at the very least, a hollow grind that isn't barely hollow) is what appealed to me. I hope I am making a big deal out of nothing. The knife hasn't even been revealed yet.
#76
As you can see it does have enough kick/ricasso to drop onto your finger, but if you hold it too car back you could definitely cut yourself.
#77
Compared to my Centofante 4. I have never had the 3 so I was surprised by how much shorter the 4 is in blade length, but that's the price you pay to get a wharnie blade into this handle shape.
It's thinner than the originals, 10.07mm on the 4 vs 7.76mm on the 3.
Although, the Cruwear 3 is heavier at 3.4oz vs 2.4oz, but since the blade length is different this isn't a perfect comparison.
#78
Wow, ultra thin! That really is tempting, very classy looking knife overall. Also even better not being laminate carbon fiber. Not that I have an issue with it, but it classes a knife down a bit in my eyes when there are other carbon fiber options available. Dang, sure is a beauty though. Wishing I didn't read this thread haha!
cabfrank
#79
Post by cabfrank »
Beautiful knife.
#80
Mon Sep 09, 2024 3:55 pm
Enablers gonna enable :winking-tongue
