Native5 Salt used to be LC200N with Yellow FRN. However, Native5 Salt changed to MagnaCut with Yellow FRN (announced but not released yet). I guess now there will be two Native5 Salt folders (more if you add serrations and DLC): LC200N with Green FRN and MagnaCut with Yellow FRN.
Reveal 10 Timing, Predictions, Discussion
Re: Reveal 10 Timing, Predictions, Discussion
- I welcome dialog, as long as it remains cordial, constructive and is conducted in a civilized manner. - Titanic: Blood & Steel
- You can fool some of the people all of the time, and all of the people some of the time, but you cannot fool all of the people all of the time. - Abraham Lincoln
Non coated lockbar is interesting to see. I wonder if the model shown on the cover is the actual production sample or just a prototype/rendering.JSumm wrote: ↑Tue May 31, 2022 12:35 pmPotential Toxic Green Native 5 Salt with LC200N. Scale color change. Lockbar doesn't look coated, so wonder what that is about.
https://i.postimg.cc/cCXBfCN7/unnamed.jpg
Could it be an LC200N lockbar?
That's what I first thought, but even with the same metal you can have galvanic corrosion I believe. I think the coating acts as an insulator.
Mushroom may be correct that it is just a prototype pieced together for the pic.
- VooDooChild
Do any of you have a lc200n native 5 salt with a coated lockbar???
The only ones with coated lockbars I saw were prototype pictures. I know mine is not coated and as far as I know none of the production native 5 salts have a coated lockbar.
Both of my Native Salts (PE and SE) have satin lockbars. The date codes are JR and FS.VooDooChild wrote: ↑Tue May 31, 2022 5:40 pmDo any of you have a lc200n native 5 salt with a coated lockbar???
Mine is uncoated, also date code JR.
Old pic...
Old pic...
So it goes.
Hmmm, galvanic corrosion is an issue of dissimilar metals with different electrode potentials. You can deal with that to some extent by using insulating coatings (until they wear) but that isn't necessary when using the same material treated the same way because the electrode potentials are the same, no electron flow, no active circuit without the battery.
I'd guess the lock bar is LC200N, I wonder if they'll do the same thing with the Magna N5?
The picture of the Reveal is up but there is no file, as yet.
Needs a countdown timer
products are up on the site!
JRinFL
Yep. It's going to get expensive for me this year.
Wandering_About
Some good fixed blades and mules in there!
MNOSD member #0035
MNOSD member #0035
- steelcity16
What does consumer direct only mean on the Chief sprint? Are they only available on the Spyderco site and factory store?
- steelcity16
Excited for the K390 Endela Wharnie and Cruwear Ayoob!
- Buddafucco
steelcity16 wrote: ↑Wed Jun 01, 2022 10:15 amWhat does consumer direct only mean on the Chief sprint? Are they only available on the Spyderco site and factory store?
It also says the DLC is $40 more than the satin!
•• Beau
JRinFL
I suspect the Chief is a dealer exclusive, but they cannot reveal which one yet. Consumer direct could mean that it will not make it to distributors.
The Massad Ayoob Sprint Run with CPM-CRU-WEAR (PlainEdge and SpyderEdge) and Gray G-10 for $210 are quite reasonable.
Designed by world-renowned firearms expert Massad Ayoob and originally introduced in 2001, the Massad Ayoob folding knife featured a distinctive negative angle between its blade and handle. This aligns the blade with the bones of the forearm to ensure a more direct transfer of force during thrusting and cutting motions and shortens the blade’s opening arc. This long-awaited Sprint Run expression of Ayoob’s design features a blade crafted from CPM CRU-WEAR®—a specially formulated air-hardening tool steel renowned for its edge holding and toughness. Its handle features full, skeletonized stainless steel liners, a sturdy back lock mechanism, distinctive gray peel-ply-textured G-10 scales, and a black-coated four-position pocket clip that provides a choice of left or right-side tip-up or tip-down carry.
