Can't get no respect
Re: Can't get no respect
#61
Thanx much.
Donut
#62
Post by Donut »
There are some people in the hard use market who think that stainless steel is too brittle to baton with. 3V might handle it, but the rest might not.
Maybe get 1095 or 5160 or something else proven for hard use for batoning and save the stainless for normal cutting.
-Brian
A distinguished lurker.
Cl1ff
#63
Post by Cl1ff »
That’s not the case in my experience, Donut.
There are a lot of factors that affect batoning, but I don’t think there is any real correlation between Stainless steel and breaking knives when all other variables are removed.
JRinFL
#64
Post by JRinFL »
According to Larrin's testing, 1095 is not a particularly tough steel. AEB-L easily bests it in toughness. 5160 & 8670 are tougher, but at lower hardness. 3V is not really a stainless steel and its toughness is close to AEB-L. So, it really seems as though most makers choose the wrong stainless steel. That said, CPM 154 should be more than tough enough for the use seen in this thread, easily besting 1095 & O1.
https://knifesteelnerds.com/2019/03/04/all-about-aeb-l/
https://knifesteelnerds.com/2020/02/17/ ... fe-steels/
Edit to add one more link: https://knifesteelnerds.com/2019/05/20/ ... ery-knife/
Djangology
#65
Post by Djangology »
I was going to start a new thread I thought I should just post this here. I've had the same thing happen to mine! First use - did some batoning and some chopping. I did about 20ish chops and then there was a ping sound as the blade went flying from the handle. The guard on mine is still fairly secure although you can muscle some wiggle now that the shoulder of the blade is no longer there. I've emailed Spyderco warranty and repair but I'm in Australia so hopefully this won't be to much of a hassle.
does anyone knows whether this issue has been addressed with a cqi?
Sorry that my first contribution to this forum after lurking since forever this tragedy!
Michael Janich
#66
Post by Michael Janich »
Dear Djangology:
I am very sorry to hear about your experience with the Respect. I recommend you send it in to Spyderco for warranty consideration.
Stay safe,
Mike
JRinFL
#67
Post by JRinFL »
Djangology wrote:
Tue Aug 10, 2021 5:17 am
<snip>
Welcome! It's unfortunate that your first post had to be about a failure, but it needed to be posted. Spyderco should take care of you.
Gerber had recall about some knives breaking this way a few years back. I wonder if Spyderco should think about doing the same before someone gets hurt?
archangel
#68
Post by archangel »
JRinFL wrote:
Tue Aug 10, 2021 7:07 am
<snip>
Exactly! This is a knife I'd expect to be fully capable of chopping or batoning from a construction point of view, and at the same time has a very heavy blade that could cause serious injury when breaking off and flying around. This must not stay like that.
Welcome Djangology, by the way. I'm confident you will be helped.
Michael
VashHash
#69
Post by VashHash »
I'm glad someone else is actually using their respect. Shame this problem arose again. Hopefully they will get you squared away. I haven't done a lot of chopping with my replacement yet. I'll have to start putting it through the paces again.
Djangology
#70
Thank you all for the kind welcome! I've sent it away today. Hopefully it is just a freak occurrence although I have a feeling that it is the squared off shoulder that is causing the issue as one poster mentioned prior. VashHash, I hope you report back with any further testing.
Cheers all.
curlyhairedboy
#71
Post by curlyhairedboy »
VashHash wrote:
Tue Aug 10, 2021 7:43 am
Eager to see if it holds up!
Trav64
#72
Post by Trav64 »
VashHash wrote:
Wed Dec 09, 2020 11:35 am
I decided to just live with the rattle of the guard. So there I was on Friday making a fire and wanted to split some 2x4s. Figured I'd use the respect to baton them. Everything was going good until it wasn't. Everyone was worried about the hole being a weak spot but apparently it was the spot where the blade became the tang for the handle. Right where it enters the guard. This isn't the first time I've used this knife this way but it was the last time. :(
I will be sending this knife in for evaluation.
Wow thats nasty
Djangology
#73
Finally got my replacement! This is such a gorgeous knife!!! Thank you to the folks at Spyderco. I'm thinking of filming the testing I plan to do. After pondering on this on and off I feel more convinced that it's the squared off shoulder that is the root of the problem but we shall see. Fingers crossed!
JRinFL
#74
Post by JRinFL »
Djangology wrote:
Sun Sep 26, 2021 10:15 pm
Thanks for posting the update.
hvarcz
#75
Post by hvarcz »
Thats weird, its the same steel?
Djangology
#76
It is the same steel.
#77
Post by JD Spydo »
Donut wrote:
Wed Jan 06, 2021 10:46 pm
I've heard that same thing about most stainless blade steels having brittle properties. And it was an old machinist that told me that a while back. To this day he won't own any knife with stainless blade steel. However I've encountered a couple of stainless blade steels over the years that I bet won't break easy. The older 440V ( S60V) seems to have a toughness that you don't find in most stainless blade steels.
And with all the harsh abuse I've put a couple of my older knives with AUS-8 blade steel through they have held up well in spite of the abuse. But that's just from personal use and I'm not offering that as scientific proof by any means. Just my personal experiences.
Cl1ff
#78
Post by Cl1ff »
I was just thinking about Bowie knives and remembered this thread.
Do we have any updates?
Btw, I cringed reading my "expert analysis" earlier in this thread. I don't think I was wrong, but you know how everything is in retrospect.
It definitely seems like the blade failures shown in this thread had a common cause, but I'm more interested in the success of any potential fix(es) or reports of no issues now.
I know Sal worked hard on the design.
Excuse me if this has been discussed elsewhere by now, since the last post in this thread is just over a year old already.
Buying one and testing it out myself isn't that out of reach for me anymore, so I may also plan to do just that.
Woodpuppy
#79
Post by Woodpuppy »
I’d love to hear from the two users who experienced the failures! Vashhash, is yours still going strong? Djangology hasn’t been back since these posts, I hope he’s been taken care of.
Cl1ff
#80
Post by Cl1ff »
Since the Respect wasn't on the discontinued list, I think thats good news for its future. I suspect that Sal wants it to stick around since it's a special knife and it'll probably receive some CQI.
