Yes, no different than corrosion resistance or toughness. Imagine if tomorrow toughness in steels was argued the same as low stress abrasion resistance. All of a sudden a knife steel was high performance only if and simply because it had a very high impact toughness. Isn't that a really silly viewpoint, of what use is the extreme impact toughness of a 4340 blade on a fillet knife - would it not be better to have a 12C27 blade which has much higher corrosion resistance, a much higher maximum hardness, more wear resistance and while it is no wear near as tough as 4340 it is tough enough for a fillet blade?3rdGenRigger wrote:Edge stability is useful in some aspects for sure, but don't discount wear resistance as useless either.
Edge retention on carpet : cKc-X, O1, S30V, k390
Cliff Stamp
Re: Edge retention on carpet : cKc-X, O1, S30V, k390
Cliff Stamp
To clarify, there is still a fair amount of work to be done before I would even feel comfortable giving that argument even minor credit. At a minimum :Brock O Lee wrote:
Intuitively your arguments make a lot of sense.
-a lower angle/more coarse finish (10 dps/x-coarse DMT)
-push cutting sharpness comparisons
I am also going to see if I can find a SEM locally because if I could see the apex at the sub-micron detail it would make figuring this out a LOT easier.
Yeah, and optimized HT for strength.bearfacedkiller wrote:
Keep it up and maybe someday we will get a FFG zero grind L6 delica. (If I am understanding all this right)
Cliff Stamp
Cliff Stamp
Summary article : http://www.cliffstamp.com/knives/articles/carpet.html" target="_blank .
Andrewmax789
hmmm this is quite interesting but not to know about its factors.Cliff Stamp wrote:Here is what happens if you scale the edge retention by the amount of grinding necessary to apex the blade :
